Author Topic: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch  (Read 72028 times)
Re: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch
« Reply #30 on: April 12, 2018, 02:30:05 PM »
Thos wings came out very sweetly!
Gaz
Offline ondra
« Reply #31 on: April 14, 2018, 12:30:07 AM »
Many thanks for following the build and leaving such nice comments, Gregory and Gazza, glad to have you on board!
Today I started working on the interior. I made a drawing of the cockpit sides in scale:
Then I fixated the drawing to a piece of aluminium with Tamiya tape, to keep it stable and prevent it from crooking:
Afterwards I started glueing evergreen profiles cut to the desired length to the respective spots with small drops of CA. Then I glued the joints with Tamiya extra thin to weld them together. At the end I got this:
Now the parts have been soaked in debonder, which should dissolve the CA and loosen the parts from the paper. Will see tomorrow, how it works out.
Ondra
Offline krow113
« Reply #32 on: April 14, 2018, 01:25:42 AM »
Magnificently tiny.
« Reply #33 on: April 14, 2018, 02:16:10 AM »
The wings are looking awesome Ondra! Your method for creating the side frames is extremely creative!
Offline ondra
« Reply #34 on: April 14, 2018, 05:10:42 PM »
Many thanks for your support, krow and Rick!
I am glad to say the method with dissolving CA has worked, the parts separated from the paper without any problem.
Today I made a fit test using white glue and for the first attempt it is acceptable.
Next up are some parts for the cockpit (seat, gas tank, dashboard etc.)
Ondra
« Reply #35 on: April 14, 2018, 10:06:59 PM »
Looks terrific Ondra!
Offline ondra
« Reply #36 on: April 14, 2018, 10:31:27 PM »
Many thanks, dear friend, I really appreciate you following the build!
I want to make sure that my drawings are correct and that all interior parts will fit in, therefore I started working on the main components.
First is the seat, in Camel's case wicker seat. I decided to use a very fine mesh I got years ago from a friend of mine.
Assembly was not as easy as I would have hoped, but eventually I got an acceptable result.
This what the seat and tank look like in the interior (not glued), so far so good.
Ondra
« Last Edit: April 15, 2018, 12:15:58 AM by ondra »
« Reply #37 on: April 14, 2018, 10:35:49 PM »
More AMAZING with each update Ondra! That seat is incredible!!
« Reply #38 on: April 15, 2018, 02:01:07 AM »
Woooof. Simply amazing what you are doing, Ondra! You are surprising us with every post.
« Reply #39 on: April 15, 2018, 06:51:07 AM »
Even considering an interior in 1/144!  I'm totally blown away.  That wicker seat is beautiful!
Gaz
Offline Jeff K
« Reply #40 on: April 15, 2018, 02:32:50 PM »
It's excellent progress on that 1/72 Camel. However, what I really want to know... Are your hands really that huge, or did you Photoshop that???
Offline Iancshippee
« Reply #41 on: April 15, 2018, 10:17:39 PM »
Ondra, those side frames and the seat are truly astounding!
« Reply #42 on: April 16, 2018, 03:27:38 PM »
Outstanding work, Ondra. The Seat is the best. I am always impressed, when you start a new build. Would love to see what you can do with a kit in lager scale. Probably it could fly.
Bye,
Offline ondra
« Reply #43 on: April 16, 2018, 10:30:30 PM »
Rick, Andreas, Gazza, Jeff, Ian and Manni, thank you very much for your nice comments and for following the build!
Today I was mainly playing around with small parts for the cockpit, I will add a few details to the machine guns and make the rudder pedals tomorrow. Today my hands are shaky already. :)
Ondra
« Reply #44 on: April 16, 2018, 10:42:08 PM »
Have I ever said that your work is AMAZING  ;D You do things in 1/144th that I have trouble with in 1/32nd. Astonishing details Ondra!
