Author Topic: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch  (Read 72128 times)
Re: W. G. Barker's Sopwith F.1 Camel B6313 1/144 scratch
« Reply #240 on: August 28, 2020, 08:27:16 AM »
Simply put, AMAZING!
« Reply #241 on: August 28, 2020, 09:44:36 AM »
Second that !
« Reply #242 on: August 29, 2020, 03:59:29 PM »
Looks sweet, Ondra!  Amazingly tiny
Offline ondra
« Reply #243 on: October 08, 2020, 02:16:09 AM »
Many thanks to all of you for your kind comments!
Finally some progress on my little Camel, she started taking shape, so I tested the fit of the engine and the cowling. So far so good.
Ondra
« Reply #244 on: October 08, 2020, 06:02:30 AM »
Really Ondra you do have ENORMOUS fingers!
I can hardly imagine how I would build that engine, let alone fir it into a scratch built cowling.
« Reply #245 on: October 08, 2020, 06:43:50 AM »
The engine is just another example of your Magic Ondra! Phenomenal build!
« Reply #246 on: October 08, 2020, 12:01:28 PM »
Wow , just simply WOW !
Offline William Adair
« Reply #247 on: October 08, 2020, 02:01:18 PM »
Wonderful work Ondra.  I've been following your progress over at KG144.  It's absolutely brilliant.
« Reply #248 on: October 08, 2020, 08:26:14 PM »
Just like William Adair's Miles Magister over on the Off Topic Builds, this is just a ridiculous build - ridiculously good in a ridiculously small scale! I don't really get how you can produce this clean kind of work in this scale! Brilliant work!
/F
« Reply #249 on: October 09, 2020, 03:59:27 AM »
Truly wonderful work, Ondra.
I can't wait to see more!
vB  ;)
Offline ondra
« Reply #250 on: October 13, 2020, 12:39:20 AM »
Many thanks to all of you for your kind comments, it is a major encouragement for the build! ;)
I added the holes to the upper wooden panel, unfortunately I screwed up on the aft one and it turned out too big. But I can live with that. I also painted the cockpit coaming and am now waiting for the oil paint to cure.
The roundels are now in place, the alignment is unfortunately not perfect. I had to use decals instead of wet transfers, therefore the process was more complicated. But I can live with it as well. :)
The wings also got a filter using oil paints, a second layer will follow once the current one has cured.
I managed to lose one of the machine guns, but creating a new one will not be a big deal.
Ondra
« Reply #251 on: October 13, 2020, 01:43:56 AM »
Amazing as always Ondra! Roundels and wash look excellent.
« Reply #252 on: October 13, 2020, 02:06:51 AM »
I am glad that you think that making a new mg will not be a problem, at least for you, because I would not like to have to make one in that scale!
More wonderful magic from your modelling area.
« Reply #253 on: October 13, 2020, 11:51:28 AM »
I'm always amazed with your work in this scale , most excellent indeed ! Looking forward on your next up-date  :)
Offline jeroen_R90S
« Reply #254 on: October 13, 2020, 06:12:06 PM »
Great stuff, Ondra, glad to see you back on this one!
