Author Topic: Eindecker Metal Work  (Read 8958 times)
Offline Ryan
« on: March 10, 2018, 06:22:18 AM »
Hello all,
I wanted to show an experiment I did on replicating the metal work on the Eindecker.
Wingnut Wings has a great method of doing this by paintbrush, but I was unsuccessful.
After some head scratching I came up with this and was pretty pleased wit the result.
Step 1. Spray Alclad aluminum.
Step 2. Using a black Sharpie draw the squiggle pattern.
Step 3. I sealed the marker with MM Metalizer, but i'm not sure this is needed as the marker did not react to lacquers.
Step 4. Mist coat Alclad aluminum to knock down the black marker and blend into the finish.
I hope this is helpful.
Ryan
Eindecker Test by The 3rd Placer, on Flickr
PS new to the forum!
Upcoming: Not sure!
Offline Dave Brewer
Re: Eindecker Metal Work
« Reply #1 on: March 10, 2018, 06:48:11 AM »
That looks terrific Ryan,I'll be trying it out next time. Thanks for sharing.
Offline Ryan
« Reply #2 on: March 10, 2018, 06:55:39 AM »
Thanks Dave, I might add that the pattern above was created with a larger tipped marker, a thin line would probably look better.
Magic Marker by The 3rd Placer, on Flickr
Upcoming: Not sure!
Offline Edo
« Reply #3 on: March 10, 2018, 04:47:25 PM »
wow! you make it sound easy! got to try!
thank you for the tip!
cioa
edo
« Reply #4 on: March 10, 2018, 05:45:42 PM »
Looks really good. Thank you for sharing.
« Reply #5 on: March 10, 2018, 06:26:00 PM »
That’s one of the cleverest and best looking hints I can remember. Great idea!
Borsos
Online RAGIII
« Reply #6 on: March 10, 2018, 11:39:51 PM »
Looks terrific! Thanks for sharing. When I get the Fokker DII I will have to try this out.
Offline Berman
« Reply #7 on: March 11, 2018, 01:06:33 AM »
Ryan,
         Alclad makes various aluminum shades. Which specific bottle did you use?
Offline Ryan
« Reply #8 on: March 11, 2018, 02:17:50 AM »
It’s an older bottle, ALC-101.
I did some final work to the floor, it’s much easier on the spoon!
Somewhat pleased with the result, pic soon.
Upcoming: Not sure!
Offline Ryan
« Reply #9 on: March 11, 2018, 06:40:59 AM »
I finished up the floor test, looks more like galvanized than the spoon but I'm happy with it.
Ended up dry brushing a little test or silver to tie it together.
Sorry no pics my Fliker app won't copy a bbc code, so click on my links in the above pics to see final pics.
Upcoming: Not sure!
Offline Ryan
« Reply #10 on: March 12, 2018, 10:08:46 PM »
Here are some shots of the floor, I had some difficulty with clear coats reactivating the pen. So think i'll switch to a acrylic clear to seal the pen work on future parts. Like I mentioned before came out more like a galvanized finish. Here is a before and after.
Metal Floor by The 3rd Placer, on Flickr
Untitled by The 3rd Placer, on Flickr
More  soon.
Upcoming: Not sure!
Offline Ryan
« Reply #11 on: March 12, 2018, 10:09:51 PM »
Upcoming: Not sure!
« Reply #12 on: March 13, 2018, 02:02:51 AM »
Brilliant! Thank you for posting this, and I'll be trying it; like RAG III I have the Fokker D.II in the "pending" line up.
Offline Ryan
« Reply #13 on: March 13, 2018, 02:31:11 AM »
No problem, I'm doing more tests and will certainly post results.
Upcoming: Not sure!
« Reply #14 on: March 13, 2018, 04:41:28 AM »
Great effect!!!
