Author Topic: Eduard Sopwith Triplane  (Read 3602 times)
Offline Softscience
« on: February 12, 2018, 05:37:30 AM »
I got a little overwhelmed about what still needs doing on my WnW Albatros, so I set it aside for now, and went back to a scale I'm more comfortable working in.
Work actually began a few days ago by drilling out all the rigging holes, and widening the holes for the wing struts. Eduard gives you little dimples at each of the appropriate location, so its a pretty easy job.
Then I began working on the engine, which has been difficult. I tried to get all the cylinders to line up, but they're just a touch off. Eduard also gives you little PE push rod things, which have been nightmarish, since they don't reach the spark plugs and crankcase completely (probably because my cylinders are off) Is there a resin alternative out there????
The PE seat went much much better.
Offline Iancshippee
Re: Eduard Sopwith Triplane
« Reply #1 on: February 12, 2018, 07:28:27 AM »
Good luck on the Tripe! Almost done with mine. Small Stuff Models does excellent resin engines, and they have both the 9z and 9b clerget available. I believe Copper State Models also offers a 9b. I’ve worked with engines from both sources and really enjoyed them. For my Triplane I pirated the engine and PE from their Sopwith Camel kit. My build log is around here somewhere!
Offline Softscience
« Reply #2 on: February 12, 2018, 10:22:57 AM »
Thanks for the heads-up.
« Reply #3 on: February 12, 2018, 06:01:59 PM »
I have the same kit, I'll follow your build!
« Reply #4 on: February 15, 2018, 04:34:40 AM »
I too have used Small Stuff engines and can strongly recommend them Ralph.
Offline Softscience
« Reply #5 on: February 16, 2018, 02:00:18 PM »
Thanks, fellas. Will look for a Small Stuff engine soon.
Meanwhile, the cockpit is getting close to done. There is a lot of brass in there, and its been tricky.
I still need to paint and insert the seat.
« Reply #6 on: February 17, 2018, 12:31:13 AM »
Great looking progress, looking forward to your updates.
« Last Edit: February 18, 2018, 09:20:37 AM by Juan »
Offline Gilly
« Reply #7 on: February 17, 2018, 07:48:21 AM »
Excellent work there Ralph, I look forward to watching this beauty come together  :)
« Reply #8 on: February 17, 2018, 11:11:50 AM »
Your interior is looking awesome! I am looking forward to your next update
Offline Softscience
« Reply #9 on: February 17, 2018, 12:51:22 PM »
Thanks, guys. I have to admit, I'm sort of winging it. The interior has been pretty tricky. It is largely finished now, though. Just the gun mount stuff, but that comes later.
« Reply #10 on: February 18, 2018, 12:31:49 AM »
Quote from RAG III  "Your interior is looking awesome!"
   That's a lot of very fine detail for 1:48 Scale, very nice work!
« Reply #11 on: February 18, 2018, 08:25:13 AM »
Got to agree with Rick and Lance: this is looking extremely good and with a Small Stuff engine will certainly be a winner.
« Reply #12 on: February 21, 2018, 06:41:35 AM »
Same here ! await more photos.
« Reply #13 on: February 21, 2018, 10:51:27 AM »
Built this kit many moons ago , very enjoyable build . Will follow along when I can . You do nice work sir  :)
