Author Topic: Sopwith Pup - WNW 1:32 scale  (Read 5223 times)
« on: February 07, 2018, 07:42:30 AM »
I thought you might be interested in my latest model, the Wingnut Wings Sopwith Pup.
I'm currently at the rigging stage, having done the tail and undercarriage rigging.  Just that with the upper wing and propeller to fit.
Then it's the figure and base to do and that'll be number 13 done.
BUILD COMPLETED - see 'COMPLETED' THREAD
« Last Edit: February 28, 2018, 06:43:25 AM by sandbagger »
Re: Sopwith Pup - WNW 1:32 scale
« Reply #1 on: February 07, 2018, 09:37:10 AM »
Awesome work! I love the weathering!!
« Reply #2 on: February 07, 2018, 10:39:21 AM »
Very nice!
« Reply #3 on: February 07, 2018, 10:41:58 AM »
Turning out quite nicely, especially the weathering.  Looking forward to your progress
Offline Softscience
« Reply #4 on: February 07, 2018, 01:49:49 PM »
Very nice. I love the shot of the underside of the tail, with all the wires back there. Looks extremely complex.
Were the seats on the pup really mounted so low?
« Reply #5 on: February 07, 2018, 03:57:03 PM »
Thanks for the encouragement guys.
I followed the kit instructions and it does seem the pilot's seat was pretty low in the cockpit.
https://www.rcgroups.com/forums/showthread.php?1540530-another-sopwith-pup/page10
Offline rhwinter
« Reply #6 on: February 07, 2018, 04:33:12 PM »
Mike, I love the Pup and its veeery beautiful, how you treated her! Especially your intense but equally subtle weathering! I‘d love to learn more about how you did that! Looking forward to seeing more of your Pup,
« Reply #7 on: February 07, 2018, 04:41:55 PM »
Great work. The weathering is outstanding. Did you use Aviattics' decals? And which one?
Bye,
« Reply #8 on: February 07, 2018, 05:17:34 PM »
Nice, nice work! It's a beautiful kit and you are doing a museum class finish on this one.
Impressive!
« Reply #9 on: February 07, 2018, 06:16:44 PM »
Manni - Yes I used the 'Aviattic' PC10 Light (ATT32089) for the upper surfaces and the the CDL (ATT32094) for the undersides. As you probably know, the Aviattic decals are totally different in both the method of application and the way they are made.  These decals are not cookie cut and therefore need to be cut from the sheet.  I created paper templates from the model parts first, then used them to trace and cut the decals. The important thing to remember is that the model surface needs to be gloss finished and totally free from any surface particles or imperfections, otherwise these will show through the decal and possibly cause 'silvering'. I have to admit the linen effect on these decals makes a big difference to the look of the model.
Rob - The weathering is a combination of fine clay washes from 'Flory Models', Tamiya Master Weathering sets and AK Interactive washes.  The Flory clay washes are water based and basically you seal the painted or decal surfaces with either a matte, semi-matte or gloss sealing coat (dependent on how much wash you want retained on the surface), then let it dry.  Once dry you can use a brush, cotton bud or tissue, slightly dampened, and remove the clay wash as required until you achieve the desired effect.  The great thing about the washes is you can control exactly how much weathering you want and if you remove too much, just put more back on and repeat.  Once done I seal the surfaces with a mix of matte and semi-matte lacquer (Alclad).
« Reply #10 on: February 07, 2018, 06:31:59 PM »
Thank You! I use the naval hex decals right now on my W29. They seem to be like a kind of plastic wrap.
Bye,
« Last Edit: February 07, 2018, 06:56:05 PM by Manni »
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #11 on: February 07, 2018, 06:47:56 PM »
looks great, I really like the way you used the Aviattic decals! Keep up the good work and show us more pictures!
Think globally, act locally!
« Reply #12 on: February 07, 2018, 07:19:42 PM »
Manni - You're right as the decals seem to have a stretch to them that standard decals don't have.  Also they are remarkably robust and can be removed and replaced or moved around with damaging them. The only thing I've found is that they don't seem to allow settings solutions, such as MicroSol, to penetrate through, as I don't see the normal effect of 'wrinkling' during the MicroSol reaction. I could be wrong here, but they don't seem to be affected.  However, if the surface has been prepared correctly, I don't think you need setting solutions as the decals hug the model surface pretty well anyway.
Ssasho0 - I tend not to keep posting pictures at each stage of the build, but instead I created a full build log, in PDF format, as I build.  Once I'm done I post a link to that build log so that anyone interested can either view it online or download it for their own reference.  The logs contain full details of the build, in both text and photographs.
Here's a link to those I've already done:
http://www.thatoneplease.co/logs.html
Offline GB
« Reply #13 on: February 09, 2018, 02:53:56 PM »
Very nice. I haven't used the Aviattic decals yet put have nust ordered a few sheets and plan to use rhem on my Felixstowe wbdn I build it.
« Reply #14 on: February 09, 2018, 07:02:47 PM »
Hi Gary,
Yes 'Aviattic' decals are the way to go.
They come as either 'clear' (transparent) or 'white' (solid backing). The clear decals require a base colour applied first, whereas the white decals don't.
For those decal sheets that are not cookie cut, you'll need to cut templates out first, using the model parts as the base. The cookie cut decals are obviously already shaped and are applied in the normal way on the model parts.
Cutting templates first sounds tricky to do but is easy enough using thin paper or similar. Also the decals are robust and do have an element of stretch in them, so minor errors transferred from the cut templates can usually be sorted out during application. Although thin, any overlap on decals of the 'clear' type will show as 'double' colour, so try to avoid that.
The thing to remember is that the surface you apply the decals to must be gloss and shouldn't have any imperfections, such as dust or heavy marks, as these will show through the decals. If any particles are under the decal there's a chance that air will be trapped there causing the dreaded 'silvering, which will show through even these decals. You can either paint the base coat colour then seal it with a clear coat (I use Alclad gloss lacquer) or paint the base colour then polish it (I use 'Flory Models' polishing sticks for this)
If you apply 'clear' decals, the base coat needs to be a gloss and light colour. White is the preferred colour but you can always experiment on a piece of plastic card first to get the desired effect. Also this would allow you to try the pre-shading colour and intensity, if you want to pre-shade.  It's what I do as post shading would cover the linen effect of the decal and contrast with the rest.
Once the decals have been applied and set fully, I apply a gloss coat over the areas that will have further decals applied, such as those from the kit itself.
When all decals have been applied I airbrush a sealing coat of 50-50 Alclad II Semi-Matte and Flat, which not only seal in the decals but also gives what I think is the correct amount of surface sheen.
Remember that the decals will cover any holes or location points on the model , but you can pick them out through the decal and carefully break through the dried decals, using a pin etc, to re-open them. Be careful not to pull at the decal as that can sometimes cause it to lift slightly.  If that happens just apply more decal setting solution to set the decal back down, pricking through the decal first if necessary.
When that's all done you can apply your weathering techniques as desired.
« Last Edit: February 09, 2018, 07:16:23 PM by sandbagger »
