Author Topic: Fokker DR1 fuselage colours  (Read 8340 times)
Offline TobyCoulson
« on: January 09, 2018, 08:10:55 PM »
I'm currently building the 1/48 Eduard DR.1 flown by Lt. Werner Steinhauser and I'm in a bit of a quandary as to the colour of the fuselage under the MGs forward of the cockpit but prior to the engine cowling. The instructions aren't clear. It looks like a light charcoal grey going by the box art but does anyone have a definite idea of the actual colour used
Thanks in advance.
Offline RLWP
  • Bodger
Re: Fokker DR1 fuselage colours
« Reply #1 on: January 09, 2018, 11:15:59 PM »
Is the rest of the 'plane in stripy camouflage? If so, it's probably going to be the same across the top
Offline TobyCoulson
« Reply #2 on: January 09, 2018, 11:44:35 PM »
Not going by this.
Offline RLWP
  • Bodger
« Reply #3 on: January 09, 2018, 11:50:39 PM »
OK, that is showing the top panels from the cowl to behind the pilot to be grey
There are other interpretations:
https://forum.keypublishing.com/showthread.php?135031-Classic-Fighters-Air-Show
Have you got a period photo of his DR.I?
Offline RLWP
  • Bodger
« Reply #4 on: January 09, 2018, 11:56:21 PM »
Here you go:
http://www.fokkerdr1.com/564_17.htm
Now you can make your own interpretation!
« Reply #5 on: January 09, 2018, 11:57:50 PM »
Pretty common color for Fokker Aircraft Cowlings and the coaming/ area in front of the cockpit. Fokker Olive Green. Same for the Axle wing and struts, although sometimes the struts were the light blue. In this case the struts are Jasta 11 red.
Offline TobyCoulson
« Reply #6 on: January 10, 2018, 01:10:11 AM »
Thanks all. Cerise it will be then  :)
RAG I’ve got some FOG in my stash I’m sure if not I’ll get something close
Offline RLWP
  • Bodger
« Reply #7 on: January 10, 2018, 01:18:24 AM »
Interesting isn't it. That first picture is probably all that the various colour profiles are created from, plus some knowledge like the Jasta 11 colours. There is precious little period information to work from
I'd say on top of the fuselage, behind the pilot, the 'cross' is actually two triangles.
« Reply #8 on: January 10, 2018, 01:48:09 AM »
Interpreting colors and patterns from ortho film can be a slippery slope to say the least. One should remember that red and an orange..ish yellow  both photograph very dark. One can "Just" make out the outline of the X on the upper deck. I would stand by the profiles personally. JMHO and No controversy intended.
PS: I think the second photo is of the Hans Weiss DR1 but I could be mistaken.
« Reply #9 on: January 10, 2018, 02:33:19 AM »
    I interpreted it as does Rick, solid Fokker olive green using the same colour as the "stripes" on the wings and fuselage. That's the best interpretation I could get from the black and white photos of "striped" DR.1's in the various references. That's just my humble opinion as well!
Offline RLWP
  • Bodger
« Reply #10 on: January 10, 2018, 03:36:11 AM »
Agreed both on the attribution of the second image and of the dangers of interpreting WWI colours
On the other hand, I am beginning to find more comfort in Peter Grosz words on colour. If someone disputes what you do, ask them to prove you are wrong....
Have you got what you need, Toby?
Offline TobyCoulson
« Reply #11 on: January 10, 2018, 04:59:31 AM »
Thanks. I agree it does look that way.
Offline TobyCoulson
« Reply #12 on: January 10, 2018, 05:02:17 AM »
Yes thanks Richard. I've found a fresh pot of Misterkit Fokker olive green and will use that
Offline RLWP
  • Bodger
« Reply #13 on: January 10, 2018, 05:13:39 AM »
You seem to have come through your first brush with WWI colour uncertainty unscathed
 ;D
Offline TobyCoulson
« Reply #14 on: January 10, 2018, 05:49:08 AM »
 ;D
My first public case of it yes.  ;D
I’ve had numerous behind closed doors.  ;)
