Author Topic: WnW Bristol F.2b  (Read 21592 times)
Offline Mutter1
WnW Bristol F.2b
« on: December 28, 2017, 01:03:20 PM »
Hello all,
  Well I managed to get a start on the Bristol. I made some of my own eyelets and then started to add more frame work and some internal rigging. I know you will probably not be able to see much of it. But hey...I know its in there!!
Offline Mutter1
Re: WnW Bristol F.2b
« Reply #1 on: December 28, 2017, 01:06:02 PM »
A few more pictures......
Offline Mutter1
« Reply #2 on: December 28, 2017, 01:17:45 PM »
A few more pictures lol
Offline davec
« Reply #3 on: December 28, 2017, 09:20:31 PM »
Looks great!  I'm planning on trying to do internal rigging for my next model.  When you drilled the holes for the crossbraces along the sides, did you drill the holes through and through from the outside, of find someway to drill them partially through from the inner edge where the loop is?
thanks!
Offline Mutter1
« Reply #4 on: December 29, 2017, 09:10:46 AM »
Hi Dave,
  I drilled the hole into the framing before I glued them into the fuselage. I had made marks for where the eyelets go.
« Reply #5 on: December 30, 2017, 01:56:31 AM »
Very nicely done, just wished all your hard work would be visible.  Looking forward to your progress.
« Reply #6 on: December 30, 2017, 02:41:00 AM »
Outstanding work! May not be seen but you have certainly added even more detail to a kit that is already great!
Offline Mutter1
« Reply #7 on: December 30, 2017, 10:10:50 AM »
Thank you RAGIII ! I have really enjoyed the build so far....a little intimidated about the rigging....but that will close to the end lol
« Reply #8 on: December 30, 2017, 10:21:38 AM »
I still class this as the best kit Wingnuts have ever produced and what you have done so far has made it even better. I built this kit when it was first released and thoroughly enjoyed the build, the rigging may seem complex but if you take your time you will handle it without a problem.
Here is a link to my build just in case you need a bit of help along the way but judging from what you have done so far you will not need any help;  https://ww1aircraftmodels.com/page7.html
Offline Mutter1
« Reply #9 on: January 02, 2018, 11:40:17 AM »
Evening everyone,
       My first attempt a doing wood grain......
Offline RLWP
  • Bodger
« Reply #10 on: January 02, 2018, 07:57:57 PM »
Well, that worked!
« Reply #11 on: January 02, 2018, 08:15:53 PM »
A really cool looking interior with all that interior rigging. The wooden tones came out very nicely as well. This is an interesting build to follow!
Borsos
« Reply #12 on: January 03, 2018, 12:11:04 AM »
Well, that worked!
Yep  8) Excellent results!
« Reply #13 on: January 03, 2018, 12:40:30 AM »
Very nice so far.
Offline Mutter1
« Reply #14 on: January 03, 2018, 09:03:03 AM »
Thank you gentlemen! Will post more as the work progresses!
