Author Topic: Aviatik DI 1/18th scale  (Read 74566 times)
Offline UFAG
Re: Aviatik DI 1/18th scale
« Reply #330 on: September 24, 2019, 05:43:55 AM »
Offline UFAG
« Reply #331 on: September 24, 2019, 05:45:34 AM »
You're right Ryan, as witnessed above..
Offline Ryan
« Reply #332 on: September 24, 2019, 05:47:30 AM »
I struggle with that as well.
The close up lens can be very cruel!
Ryan
Upcoming: Not sure!
« Reply #333 on: September 24, 2019, 05:53:43 AM »
Your continued pursuit of excellence is amazing! I see No issues even enlarged that I would have a problem with  ::)
Offline UFAG
« Reply #334 on: September 24, 2019, 06:02:25 AM »
Thnx Rick..!!
Comforting to know btw that I am not the only one struggling with the close up pics...
To the eye, the subject looks good, once posted and blown up like crazy, eeehhh...it looks slightly different and one wonders "what went wrong here"... ;D
Offline UFAG
« Reply #335 on: September 24, 2019, 06:30:49 AM »
Cockpit parts adding up, now the controle column...will follow the Albatros DVa 1/16 scale routine.
Offline UFAG
« Reply #336 on: September 24, 2019, 06:31:32 AM »
Offline Ryan
« Reply #337 on: September 24, 2019, 06:58:02 AM »
Wonderful.
Upcoming: Not sure!
« Reply #338 on: September 24, 2019, 07:00:19 AM »
That seat looks really comfortable, so Frank will have to wait until I have had a chance to warm it! And please would you be kind enough to crank the propellor and start the engine for me when I take it up on its first flight?
Such detail....and I do not see any problem with the rudder bar either.
Offline UFAG
« Reply #339 on: September 25, 2019, 04:38:33 AM »
Okay, somewhere on the forum ( I do not no anymore who, where and the subject involved), a topic about covering the prop blade tip with metal, it was a four blade prop, that I do recall.
Anyhow, it inspired me to try something my self.
I used alu sheet - 0,11 mm - ( used by book printers way back in the past).
I annealed it with a torch for a very short time ( other wise the alu will melt).
Cut to shape, glued on with epoxy and let it dry for a while.
Fine sanding completed the process, rivet with a fine needle ( this was done in a hurry, no fine sequence)
After annealing, the alu is very malleable.
Offline UFAG
« Reply #340 on: September 25, 2019, 04:41:19 AM »
Offline UFAG
« Reply #341 on: September 25, 2019, 04:43:06 AM »
The prop is 1/48 scale, home made, but rejected.
Back to the Aviatik...
Offline Ryan
« Reply #342 on: September 25, 2019, 05:14:46 AM »
Good test piece.
Upcoming: Not sure!
Offline UFAG
« Reply #343 on: September 25, 2019, 06:48:50 AM »
Now I do recall, Frank ( Bughunter)
Offline UFAG
« Reply #344 on: September 25, 2019, 11:38:02 PM »
