Author Topic: Max Immelmann's Fokker E.I 13/15 scratch 1/144  (Read 55051 times)
Re: Max Immelmann's Fokker E.I 13/15 scratch 1/144
« Reply #105 on: September 11, 2017, 05:22:49 AM »
The cylinder looks perfect Ondra. I am looking forward to seeing the completed engine!
Offline ondra
« Reply #106 on: September 14, 2017, 02:31:55 PM »
Many thanks for your nice comments, Stephen and Rick!
Last night I found a bit of time for the workbench, so I continued with the engine assembly and added a few details. It is not perfect but quite good for the first try.
I also started working on details on the fuselage bottom. I would like to use a method very similar to the one I use for making ribs - I apply the masking tape and afterwards I spray several coats of surfacer. Once the tape is removed, the edges should create good guides for the stitching and for the hatch beneath the cockpit.
Ondra
« Last Edit: September 14, 2017, 02:38:00 PM by ondra »
« Reply #107 on: September 15, 2017, 03:39:37 AM »
More of your micro-magic Ondra. Your skills a first class - do you suffer from eye strain? I know that I would.
Stephen
« Reply #108 on: September 15, 2017, 04:57:43 AM »
You should work together with SmallStuff, since until now they offer rotary engines in 1/72 and 1/48. May be yours will be the master for the first 1/144.
On the other hand I don't know, if there is a market. Only you are able to build the small WWI aircrafts in that small scale!
Offline ondra
« Reply #109 on: September 15, 2017, 03:02:53 PM »
Many thanks for your nice comments!
@Stephen: no eye strain so far, but I have to make regular breaks as my hands get shaky after about 30 minutes of fiddling about with the tiny parts :)
@Frank: As you mention, I am not sure there actually is a market. There are WWI kits available from Valom and Sram in 1/144, there even is a D.H.2 stripdown (!) in 1/144 available from Brengun, but I saw very few kits in this scale actually built.
« Reply #110 on: September 15, 2017, 03:45:00 PM »
This is miniaturization at its best, a real wonder so far!
« Reply #111 on: September 15, 2017, 10:13:07 PM »
Your work at this scale is truly inspirational.   ;D
« Reply #112 on: September 15, 2017, 10:34:06 PM »
Ondra,
Your engine is a beauty! I am looking forward to seeing the results on the stitching and panel!
Offline ondra
« Reply #113 on: September 18, 2017, 12:12:47 AM »
Many thanks for your nice comments, Giuseppe, Juan and Rick, they are highly appreciated!
Not much time for the workbench this weekend, so just a slight progress.
I removed the masks from the fuselage belly and after a bit of sanding the result looks acceptable.
I also added the ribs to the tailplanes:
And started adding details to the undercarriage, still a lot of work ahead on this one:
Ondra
« Reply #114 on: September 18, 2017, 04:00:29 AM »
I would have shaky hands in 30 seconds working with those tiny parts! More magnificent modelling from a master.
« Reply #115 on: September 18, 2017, 04:58:24 AM »
Not to mention going blind.  Outstanding job Ondra, never gets old looking at your workmanship.
« Reply #116 on: September 18, 2017, 06:58:09 AM »
Ondra, you add here details on your model, which sometimes are missing in bigger scales :o
Fantastic work!
« Reply #117 on: September 18, 2017, 04:45:57 PM »
I follow silently, enjoying every single step!  8)
Antonio
Offline ondra
« Reply #118 on: September 19, 2017, 02:20:12 PM »
Many thanks for following the build and leaving such generous comments, Stephen, Juan, Frank and Antonio!
Yesterday I made a bit of progress on the engine by adding the push rods, now it is ready for painting.
I also added the stitching to the fuselage, but I am not very satisfied with the result, therefore I will rework it.
Ondra
« Reply #119 on: September 20, 2017, 12:42:52 AM »
Beyond AMAZING Ondra!
