Author Topic: Another double build: Sopwith Pup (HR Models) and Triplane (Revell), 1:72  (Read 32791 times)
Re: Another double build: Sopwith Pup (HR Models) and Triplane (Revell), 1:72
« Reply #105 on: August 06, 2017, 05:36:05 AM »
Thanks folks!
 A little more progress this week, in that the undercarriage on both has been rigged...
 Unfortunately the Tripe's is slightly off centre, but it'll have to stay that way now....
I also got most of the Tripe's aileron rigging done. It just needs to be trimmed off. I made a bit of a mistake here, in that I assumed that the wires would continue over the horns and back to the ailerons. Unfortunately after looking at pics only the Pup's underside has this set up, so I now have to carefully tidy up the holes, which should have been done before adding the decals.
Thanks for looking in!
« Reply #106 on: August 06, 2017, 06:08:56 AM »
Terrific rigging Ian! The triplane was difficult in 1/32nd scale but you have nailed it in 1/72nd!
« Reply #107 on: August 08, 2017, 04:43:30 AM »
Thanks Rick!
 Another brief update..... The tail rigging is also now done, and I've added the tail skid and rudder. That will be rigged tomorrow after it's had a good chance to set properly!
nearly there.....
Offline xmald
« Reply #108 on: August 08, 2017, 02:01:23 PM »
What a great looking pair of PC 10 in the making!
Best regards
Filip
« Reply #109 on: August 08, 2017, 04:52:16 PM »
Beautiful parallel slalom!
Antonio
« Reply #110 on: August 09, 2017, 12:00:30 AM »
Excellent tail rigging!
Offline Iancshippee
« Reply #111 on: August 09, 2017, 07:51:10 AM »
Excellent Sopwiths! Sir Thomas would be proud!
« Reply #112 on: August 11, 2017, 04:39:38 AM »
That is super rigging Ian. Like the rest of the build it is difficult to appreciate that this is 1/72 (ie the True), scale.
« Reply #113 on: August 13, 2017, 04:04:26 AM »
Many thanks to Filip, Antonio, Rick, Ian and Stephen for the kind comments!
The Triplane is now finished! I added the last of the tail rigging this past week, then this morning I added the final bits - wheels, prop, pitot tube and windscreen. The latter was cut from clear plastic packaging, CA'd in place, then I ran the smallest brush I had around the edges to give it the padded leather look. Both were done at the same time, so the Pup also has her windscreen now.
 Here's the screen being shaped. I left it attached to the main body of the plastic to make it easier to hold, then snipped it off and gave it a final clean up.
and here it is in place and painted
as you can see, I should have filled the indents in the fuselage for the cabane struts as they are too far inboard, but by the time I realised it was too late and I don't want to risk messing up the surrounding area to try to fill the gaps. It really isn't too noticeable in "real life", but just a tip for anyone else attempting this one!
and here she is, a few last touchups still needed but that's all.
 The weather is very dull today, hopefully tomorrow will be sunny and I can get some decent pics and post her in the completed section.
As soon as I get the PE for the Pup I will continue with her.
« Reply #114 on: August 13, 2017, 04:13:38 AM »
Outstanding results Ian. It has been a pleasure watching these come together!
« Reply #115 on: August 28, 2017, 05:51:18 AM »
Thanks Rick!
I finally got back to the bench this morning and finished off the control and tail rigging
She's sitting upside down now waiting for the wheels and tailskid to dry, so tomorrow I hope to complete the touchups and post the RFI pics!
« Reply #116 on: August 28, 2017, 07:18:13 AM »
Outstanding Ian! It has been great following this dual build!
« Reply #117 on: August 29, 2017, 05:37:55 AM »
Many thanks Rick,
 Here's the final result.....
 She's now taken her place in the cabinet, replacing the rather sorry looking Airfix one, which has served its purpose well.
More pics in completed section, many thanks to all who have followed along and given encouragement!
