Author Topic: Ansaldo A.1 Balilla Polish (1/32, Aviattic)  (Read 54735 times)
Re: Ansaldo A.1 Balilla Polish (1/32, Aviattic)
« Reply #135 on: June 29, 2017, 01:29:50 AM »
Wholly agree with Rick's last comment: this is turning into a first class model in every way.
Offline xmald
« Reply #136 on: June 29, 2017, 06:29:49 PM »
Przemek - what can I say what hasn`t been already said - your model is truly superb!
The rigging seems to be a little bit tricky here.
Are you going to weather/ shade or apply the wash over the plywood or is it the final result?
Best regards
Filip
« Reply #137 on: June 29, 2017, 06:46:55 PM »
Thanks, Stephen and Filip.
Filip, I am still thinking of adding some dirt around the engine. But I do not want to exaggerate. Only delicate wash, probably. Yet, there is some already, around the PE fittings.
Offline KrzysiekK
« Reply #138 on: June 29, 2017, 07:09:34 PM »
The rigging constitutes main problem with Balilla's replicas. I had same task in 1:48, but in this case it looks like it should do. So great work!
regards
K
Offline Adam
« Reply #139 on: June 29, 2017, 07:21:19 PM »
I keep my fingers crossed.
I believe that you can do it with the rigging.
Adam.
« Reply #140 on: June 29, 2017, 11:23:23 PM »
The work you have done to prepare your rigging is Brilliant as always! I am looking forward to the results.
Offline Edo
« Reply #141 on: June 30, 2017, 03:14:20 PM »
Being speechless in front of Preze's majesty in building this wonderful plane, I can only add some historical background on the name "Balilla", that maybe, not all of you are aware of.
Balilla, actually was the nikname of Giovanbattista Perasso, born in Genova in 1735 who, at the age of 11, sparked a revolt agains occupaying Austrian forces by throwing a stone to a group of soldiers forcing people to pull a gun from the mud.
Balilla became soon an heroic symbol and was later used in Italian fight for unity in 1800s and still later by Mussolini that gave his name to a paramilitary organization which scope was to teach children (from age 8 to 11) how to be good citizen according to fascist principles (other 'classes' were in place from age 6 to 21).
Ansaldo an industrial construction conglomerate established in 1853 in Genova gave the name Balilla to this little but full of pepper plane.
ciao
edo
« Reply #142 on: July 01, 2017, 12:27:43 AM »
Thank you for the background on the name, Edo.  I've often wondered about it.  I just assumed it had something to do with birds.  That is a very cool story.
Offline Alpha Delta 210
« Reply #143 on: July 01, 2017, 06:33:54 PM »
Sensational rendition of a type that is unfamiliar to me. I must go off and do some research!
« Reply #144 on: July 02, 2017, 05:32:05 AM »
Thank you, everybody. Also special thanks for Edo for the historic background on Balilla. I remembered reading this story some time ago but failed to know all the details, now it will surely remain for a longer time. ;)
Some more progress led me to almost complete this model. Rigging is done - tying the tapes was an experience, their stiffness made it much more complicated than with usual flexible lines. Especially, passing the flying ones through the gap in the parking ones was straining. After some small disasters with lines torn from the plastic bands I finally made it. The rest was much easier - drag lines, aileron pushers, propeller... Now only squadron badges decals are missing. But here I am at mercy of Melius Manu. With this - time for holidays!!! :-)
« Last Edit: October 12, 2017, 08:50:34 PM by PrzemoL »
Offline aliluke
« Reply #145 on: July 02, 2017, 08:40:09 AM »
Amazing!!!! Bravo. Endless applause - a masterpiece.
Alistair
« Reply #146 on: July 02, 2017, 08:44:13 AM »
Stunningly beautiful! Your rigging obviously worked out perfectly!
Offline Adam
« Reply #147 on: July 02, 2017, 08:47:15 AM »
You are the master, Przemek. You can solve any problem.
Adam.
« Reply #148 on: July 02, 2017, 09:28:55 AM »
Cannot agree more, outstanding.
« Reply #149 on: July 04, 2017, 05:57:22 AM »
Thank you for your kind words!
