Author Topic: Caudron G4 "Butterfly" C74 1916  (Read 58603 times)
Re: Caudron G4 "Butterfly" C74 1916
« Reply #60 on: April 03, 2017, 07:35:56 AM »
Great progress on the wings and the nacelle. You are building a real masterpiece, xan! It's a pleasure to follow your build.
Borsos
Offline xan
« Reply #61 on: April 06, 2017, 04:52:13 PM »
Hello, same colors for upper surface of the lower wing
OK, I surely exagerated a little bit oil marks...
i will see how it lools like at the end; it's only a PE part easy to clean if I want to paint it again...
I started a weathered plane so...
this pic show there was oil under the engines anyway...
here how to will loock like; I think it won't be too much at the end...
Xan
Xan
« Reply #62 on: April 08, 2017, 04:39:10 AM »
Xan,
I have studied many photos of these aircraft when I built mine and it was clear that the engines poured out a huge amount of oil (as all rotaries did), so I do not think that you have overdone the pool staining. In fact there were two small drain pipes on the lower sides of the cowling which were obviously there to take the oil away.
The rest of the build looks superb - a masterpiece in the making.
Offline xmald
« Reply #63 on: April 08, 2017, 09:35:31 PM »
I totally agree with Stephen! The weathering is spot on -not overdone in any way. When I`ll be building the second Caudron for me it`ll be a way more weathered than the one I`m finishing now.
Your model is a distant example of perfection to follow for me. Distant because I still don`t have such skills as you do!
Best regards
Filip
« Reply #64 on: April 09, 2017, 02:08:58 AM »
I can only join in: Really a wonderful build, great weathering and in no way overdone!
It is a joy to follow your build!
Borsos
Offline Jorgo
« Reply #65 on: April 09, 2017, 03:52:51 AM »
Xan, I can only echoe Filip and Andreas, very nice weathering and oil streaking - chapeau!
Jörg
« Reply #66 on: April 10, 2017, 05:51:52 PM »
Xan! Totaly agree to what is said above. I love the dozens of different tones you have archieved in your build.
« Reply #67 on: April 15, 2017, 03:34:10 AM »
I have to agree with all of the others. Beautifully weathered!
Offline xan
« Reply #68 on: April 15, 2017, 08:22:33 AM »
I'am not going on quick
I listened my models masters abd did again the metalic xwing protection under the engines.
I thought that represent the rivets was quite interesting . I let archer rivets in natural blach...
Xan
Offline xan
« Reply #69 on: April 16, 2017, 04:30:59 AM »
I put the ring of the ringging...
and the first ringging !
Xan
« Reply #70 on: April 16, 2017, 05:08:29 AM »
Wow Xan, truly amazing work.  Turning out to be a mini masterpiece.
« Reply #71 on: April 16, 2017, 05:10:13 AM »
Gotta Agree !!!!
Offline Syd Solo
« Reply #72 on: April 16, 2017, 03:11:19 PM »
 Xan
Your realism is outstanding!
I am really enjoying this build.
Syd
Offline xan
« Reply #73 on: April 16, 2017, 07:12:51 PM »
thanks!
last works:
next step, the srtuts
Xan
« Reply #74 on: April 16, 2017, 11:12:07 PM »
Xan,
    Just checked back into this post, really impressive work. I think your representation of the oil and "grunge" is spot on, nicely done! (as is all the work thus far!)
