Hints and Tips/Questions about modeling
Painting the wing edges on a WNW Sopwith Pup
Topic: Painting the wing edges on a WNW Sopwith Pup (Read 2899 times)
Burbankbill
Guest
January 23, 2017, 02:57:08 AM »
Hell;
Whats the easiest way to mask the wing edges on the wings.
Bill
Burbankbill
Guest
Re: Painting the wing edges on a WNW Sopwith Pup
January 23, 2017, 03:07:12 AM »
Thanks I will try that.
Bill
Berman
January 27, 2017, 07:10:15 AM »
Here is an alternative method. Tape around the perimeter of the wing. The tape width does not matter. Construct a cutting tool consisting of a number eleven scapel bladed epoxied to a wood stick with the correct width shim representing the width of the painted edge. The wood stick should extend beyond the tip of the blade to act as a guide. Use this tool to cut away the masking tape.
lcarroll
January 27, 2017, 12:15:27 PM »
I've got my best results using carefully cut "panels" of Aviattics CDL White backed decal. Overlap to the bottom surfaces as wide as you wish and the Decal Shape when applied will define the overlap band.
drdave
January 29, 2017, 05:17:00 AM »
I found a cheat. A pc10 coloured fabric marker pen!
I found it in a craft shop. Chisel tip one end and pointed the other. I drew them on.
macsporran
January 29, 2017, 05:38:32 AM »
Quote from: Drdave on January 29, 2017, 05:17:00 AM
Is that impervious to various types of varnish, Dave? I've tried several but they've all leaked when I applied varnish or Future/Kleer.
(Total disaster with a Ruston 1000th Camel some years back.)
What brand of pen?
Thanks
