Author Topic: Painting Spandau's help  (Read 2135 times)
Offline kajones1644
« on: December 26, 2016, 06:59:07 PM »
Hi
Any tips or advice in painting the forward slotted section? I want to ensure I can get enough paint in with my airbrush to ensure coverage of the barrel but at the same time done want to flood the exterior.
Many thanks in advance
Keith
Re: Painting Spandau's help
« Reply #1 on: December 28, 2016, 09:17:08 AM »
Mist the paint on in very light coats until you get the effect you are after . Flat base paint will cover the area easier the a gloss paint will and take less coats .
« Reply #2 on: December 28, 2016, 10:50:13 AM »
I am normally using brass rod for the barrel as I use a burnishing liquid to blacken the brass barrel and the PE cooling jacket. If using Gaspatch guns, I'd recommend painting the barrel before inserting it into the cooling jacket.
Hope that helps
Borsos
