Author Topic: Nieuport 28c1 (Roden 1/32) from Chowhound  (Read 9269 times)
Offline chowhound
« on: November 23, 2016, 03:15:47 AM »
Hi guys,
after a long, long time, I'm back again. ;D
So, after my "maritime" phase with Pearl Harbor is finished, and the Ray / Missile-Driven Division is now ready, I thought I could return to the childhood days of the military flight. I had already started with the "Ninak", but this site is closed for the time being, because I want to start some tests on some other models, before I even use them with the Ninak (the kit is just too expensive for me to go wild To experiment). Here is a somewhat slimmed down building report on the Nieuport.
The kit is from Roden in 1/32 scale. Since relatively few components (56) are available, and the detailing is also worth improving, so the perfect model for trials. The first thing I did was the cockpit. Normally, you paint a large part of the components before the assembly, but you should cancel it for later. And for a simple reason. All parts are glued "dull", since Rodentypically hardly any travel aids (bores / pins) are present. This makes these kits for beginners not exactly "user-friendly". After the parts were dry, the scaffold was glued and painted in a light wood tone. The seat was repaired because Roden offers here only a simple seat shell, which looks more like from the 2. world war. Here I have a basket netting, which does not look quite like the original, but fully fulfills my ideas.
Furthermore, various bowden cables and tension wires were installed. Also, I've used seat belts from Eduard, since Roden does not offer (even times apprehension).
We continue with the engine. Again, there is still a lot to be improved, even if one later by the engine cover hardly sees anything.
Thus, the cooling fins were carefully recessed, second spark plugs fitted (the engine had already two spark plugs per cylinder to compensate for a failure), and the corresponding ignition cables laid. Lacquered in iron, aluminum and metalic-black.
The bonnet was completed by a rivet row.
Now I have devoted myself to the most foolish thing. The tension wires. Since the French, as well as the German aircraft, used round tension wires, it was obvious for me to make these wires myself, since I do not like the use of yarn. I made the wires from 0.03 and 0.1 mm copper wire. The sleeves are made of 1 mm brass tube.
Since the transverse side and height rudders are unfortunately not available individually, these were carefully cut with a scalpel, and re-attached with pins.
Since the wing struts are indeed a very delicate matter, as far as attaching (tacking), the paint finish was finished so far. On the top of the wing, narrow strips and nails were sculptured in the area of ​​the ribs.
The cockpit, by the way, is pushed completely into the fuselage, and not as usual, glued into one of the trunk halves.
In the current state, the middle panels are glued to the fuselage and also the bracing is finished so far in this area. The tensioning ropes are turned again, this time with a diameter of 0.05mm. The sleeves are made of carbon with an inside diameter of 0.07mm. For comparison, I have placed a pin on the last photo.
That would be it for the moment. (Sorry for the translation, it's Google-Translate  :-[)
Jürgen
Every artist was first an amateur.
Ralph Waldo Emerson (1803-1882)
Re: Nieuport 28c1 (Roden 1/32) from Chowhound
« Reply #1 on: November 23, 2016, 04:51:57 AM »
You're off to an excellent start, Jürgen!  Looking forward to following along on this one.
« Reply #2 on: November 23, 2016, 05:26:36 AM »
Excellent start. I did not know that this was available in this scale but you are making some very good improvements: when you are finished it will look more like WNW than Roden!
« Reply #3 on: November 23, 2016, 05:47:54 AM »
What a great job you are doing on this model, the cockpit turned out splendid and the camo paint colours are excellent, looking forward to seeing more.
Offline chowhound
« Reply #4 on: November 23, 2016, 05:52:18 AM »
Thank you!
@Stephen,
what you mean with "available in this scale", the kit or the extra parts?
Jürgen
Offline chowhound
« Reply #5 on: November 23, 2016, 06:10:45 AM »
A litle note to the Nieuport kit. Roden has simple the 1/48 kit scaled up to 1/32. Also the kit is not very accurate. For example, the upper wing is nearly 3mm to short, and some parts, as the wheels (wheel blind with the hole is inside instead outside) are wrong mounted. And so on. :(
Offline rhwinter
« Reply #6 on: November 23, 2016, 06:21:15 AM »
That looks very fine, Jürgen!
 It's such a pity: Roden offers so many very interesting types, but the lack of quality(SOMETIMES) is discouraging. Nevertheless I got me some of my favourites like the Fokker D.VI, the Siemens-Schuckert D.III and the Albatros D.I. The Nieuport 28 is one of my boyhood heroes too, but I still hesitate to buy the Roden kit...
Looking foreward to your build of the kit, Jürgrn!
Online lcarroll
« Reply #7 on: November 23, 2016, 06:38:37 AM »
    Great start Jurgen, and as Des has remarked as well the colours are excellent. I have built this Kit and, with a little extra care and effort, it builds into a very nice model. I didn't worry about the wing dimensions as 3mm on a model this size is not noticeable. I'll be following your Build with great interest!
« Reply #8 on: November 23, 2016, 07:15:11 AM »
Great start Jürgen, looking forward to your progress.
« Reply #9 on: November 23, 2016, 08:41:28 AM »
Outstanding start on your Nieuport. As all of the others have said your colors look excellent. I too have built this kit and agree with Lance as to the results possible with a little effort. You are doing a fantastic job on yours!
« Reply #10 on: November 24, 2016, 11:37:19 AM »
Wow , your moving right along on this build , looking really nice so far .
Offline chowhound
« Reply #11 on: November 27, 2016, 01:11:11 AM »
Thanks for the positive echo.
And it goes on with a small update.
The upper and lower wings are joined together. In the case of double deckers, this section is always one of the most critical moments, since the connection between the wings takes place via thin struts. It's going very fast, something's going wrong. That is why I have first only the middle struts, which come from the trunk with the upper wing glued and dry well. Only then were the four lateral struts attached. As a result, no correction is necessary any more, and everything is ready for the installation of the prepared tension wires.
Roden has unfortunately also a mistake with the wheels installed. The wheel cover with the buckle belongs to the outside of the landing gear! So I had to drill a new axle hole and close the other axle hole. Since the wheels were fastened with a hexagon nut on the axle, I made a dummy from a hexagonal profile, and glued it.
To be continued!
Jürgen
« Reply #12 on: November 27, 2016, 02:06:44 AM »
Nice progress, which pilot markings are you using for this aircraft?   Looking forward to your progress.
« Reply #13 on: November 27, 2016, 03:54:46 AM »
Very impressive so far, especially that hexagon nut! Looking forward to more.
Offline chowhound
« Reply #14 on: November 27, 2016, 04:30:22 AM »
Hi Juan,
It will be the number 12, flown by Lt. Edward Rickenbacker,  France, April- May 1918.
