Author Topic: LVG C.VI, Pegasus 1/72  (Read 41700 times)
Offline steveb
Re: LVG C.VI, Pegasus 1/72
« Reply #45 on: December 05, 2016, 05:36:06 AM »
Wow, things are really taking shape!
« Reply #46 on: December 05, 2016, 07:51:38 AM »
That's looking fantastic, I love the colour of the wood.
« Reply #47 on: December 05, 2016, 08:06:53 AM »
Great looking so far, keep working your magic.
« Reply #48 on: December 05, 2016, 08:54:45 AM »
Your interior looks terrific! Great work all around!
« Reply #49 on: December 05, 2016, 05:50:19 PM »
Very good work on the interieur. It looks just great.
« Reply #50 on: December 06, 2016, 04:02:36 AM »
Very, very nice Wolf! Very difficult to believe it is 1/72 - and a pleasure to view all that detail before you close it up! Regards, Marc
Offline Wolf
« Reply #51 on: December 06, 2016, 10:53:29 PM »
After I have glued the fuselage halves together, further problem areas showed up. There were some gaps between the halves and two areas were subisidiences could be found. A minor one on the left side behind the engine and a bigger one on the right lower fuselage.
I avoid the use of putty wherever possible or reasonable. So I filled the gaps with stretched sprue and the subsidiences with plastic sheet.
The use of thin plastic cement (Tamiya extra thin) makes it easy to bond the sheet and stretched sprue with the fuselage but it needs some time to cure. Therefore I will wait 48 hrs (I think 24hrs will be ok too) before I continue.
« Last Edit: December 01, 2017, 12:26:46 AM by Wolf »
« Reply #52 on: December 07, 2016, 01:33:00 AM »
Excellent work using the plastic sheet and sprue to fill and even out the fuselage halves!
« Reply #53 on: December 07, 2016, 02:12:51 AM »
Outstanding craftsmanship on this one, Wolf!  She's sure to be a beauty when finished.
« Reply #54 on: December 07, 2016, 08:06:45 AM »
I agree that you corrections are very good. I usually allow 24 hours for glue to cure and generally have no problems. If you are able to file/sand the plastic corrections down and achieve the standard that you have reached so far on the rest of the build nobody will know what you have doe. This is first class modelling.
« Reply #55 on: December 07, 2016, 09:30:53 AM »
Lovely work on correcting the faults with the fuselage. She's coming on well!
Offline Wolf
« Reply #56 on: December 09, 2016, 11:36:07 PM »
And this is the result after some sanding
No putty beside a minor spot at the top left cowling.
« Last Edit: December 01, 2017, 12:28:46 AM by Wolf »
« Reply #57 on: December 09, 2016, 11:42:17 PM »
Excellent results!
« Reply #58 on: December 09, 2016, 11:58:06 PM »
Looking really good.  Your efforts have really paid dividends.
« Reply #59 on: December 10, 2016, 03:01:17 AM »
That is by far the best way to correct those kinds of errors. After a coat of paint nobody would know.
