Author Topic: LVG C.VI, Pegasus 1/72  (Read 41493 times)
Offline Dirigible-Al
Re: LVG C.VI, Pegasus 1/72
« Reply #150 on: January 13, 2022, 02:14:32 AM »
Great improvement on the Benz engine. I will be following with interest.
Alan.
« Reply #151 on: January 13, 2022, 03:18:42 AM »
I think I may have missed the earlier phase of this build so I'm glad I can see it with fresh eyes and enjoy your new updates. Had you not mentioned the kit origins in the title I'd have thought this was 1/48 - great recovery Wolfgang! More power to you  :)
« Reply #152 on: January 13, 2022, 05:20:51 AM »
Wolf, it is so great to see you again here :)
A decision was to made. Trash or try?
Luckily you decided to work on it!
It would have been a real shame to lose this wonderful paint job on the fuselage and all the work on the other parts.
Hope you can finish it now "in one go", without additional 3 years for the undercarriage ;)
« Reply #153 on: January 13, 2022, 05:50:29 AM »
Yes it is good to see this one is back and being built. The finish on it is so good that it would be a real shame to consign this to the bin. Looking forward to seeing it in the completed models section soon.
« Reply #154 on: January 13, 2022, 09:41:41 AM »
Wolf,
        I'm so glad you resurrected this build!  It's lovely.
WD
« Reply #155 on: January 13, 2022, 07:24:35 PM »
Hi Wolf
Regarding my last post I only saw the first page and somehow missed the rest of this thread. This is a superb build!
Alan.
Offline Wolf
« Reply #156 on: January 14, 2022, 01:59:40 AM »
Thank you gentlemen. Nice to be back
With finishing the rigging, I am one step further now than three years ago. A good feeling
« Reply #157 on: January 14, 2022, 05:16:19 AM »
Beautiful rigging, Wolf! I can only imagine how satisfying it was to finish that and look back on how things have progressed.
« Reply #158 on: January 14, 2022, 09:35:39 AM »
Beautifully rigged wolf!
Offline Wolf
« Reply #159 on: January 15, 2022, 01:32:09 AM »
One last big hurdle is the undercarriage (there are also some small ones left). The kits struts  where roughly formed white metal pieces. After cleaning and sanding them into shape to be sufficient for the scale, they seemed to be to soft und fragile. I didn't trust them and made the decision to replace them with scratch made parts.
I used brass struts (my stock of Strutz parts is emptying slowly but steady) which had to be filed somewhat thinner. After this was done, I smothed them between two nail files.
In the next step a v-shaped notch was filed into the strut, then I bended the strut in the direction of the notch, using a scetch as guidance
Then the tip was soldered and again filed
In the last two steps, I drilled a hole into the tip and then everything was filed and sanded into shape
Thes first side of the undercarriagewas ready
I used the kit part For the center part of the undercarriage but exchanged the en bloc casted front bar with a separat brass bar.
then I fixed it on my workbench, using it as guidance for the struts which were glued to the fuselage with two compund adhesive. The two Lego bricks supported the correkt high and straightness. (sorry for the low quality picture)
Offline Radarman
« Reply #160 on: January 15, 2022, 01:55:41 AM »
Wolf,
It looks like this one will be off your bench very soon. I know what you mean about "Strutz", my stock
is also dwindling.
                                                              Happy modeling,
                                                              Kevin
« Reply #161 on: January 15, 2022, 05:55:17 AM »
Superb work on the replacement landing gear, Wolf!
« Reply #162 on: January 15, 2022, 05:58:54 AM »
That is awesome work on the struts, especially in 1/72nd scale! The model looks great resting on the gear.
« Reply #163 on: January 15, 2022, 09:40:07 AM »
Brilliant work and solutions Wolf.
WD
« Reply #164 on: January 15, 2022, 04:10:17 PM »
Looks beautiful and highly improved.
