Author Topic: Bristol F.2B Fighter (1/32, Wingnut Wings)  (Read 36319 times)
Offline Edo
Re: Bristol F.2B Fighter (1/32, Wingnut Wings)
« Reply #75 on: November 05, 2016, 04:39:55 PM »
yes, Preze, the photos are back! and what a great photos they are! you did a great and neat build! it just seems the real thing!
ciao
edo
« Reply #76 on: November 06, 2016, 08:20:52 AM »
Thank you, Edo.
Some more steps FORWARD!  :)
The upper wing jumped on. I decided that fitting the wing to 12 struts at one run would be too much for me. So I only used cabane and outermost ones first and put the upper wing on without the mid-span ones. When glue dried I rigged the cabanes and 4 outermost stagger lines. Then I slipped in the remaining 4 struts (with pins slightly trimmed to ease the process) and rigged their 4 stagger lines, too.
And now it is all about rigging! Two inner bays have now their landing wires and four inner flying wires. And I have enough for the day.  ;)
« Last Edit: October 12, 2017, 10:10:55 PM by PrzemoL »
Offline rhwinter
« Reply #77 on: November 06, 2016, 06:33:05 PM »
Great!
« Reply #78 on: November 07, 2016, 12:10:27 AM »
Wow, she is looking beautiful.
« Reply #79 on: November 07, 2016, 01:13:22 AM »
Great, beautiful work.
« Reply #80 on: November 07, 2016, 01:18:59 AM »
lovely job Prze,
I had one and sold it on but wish I hadn't now.
« Reply #81 on: November 07, 2016, 01:21:29 AM »
Lovely work, and very inspiring! I started one of these kits (in tandem with another WnW German 2-seater) and am following your build as a guide.
« Reply #82 on: November 07, 2016, 06:36:13 AM »
Awesome work, my friend.  The rigging is superb.
« Reply #83 on: November 08, 2016, 05:31:55 AM »
This build is looking truly magnificent, Przemo! I do love your approach to rigging, very neat and precise, and always such beautiful modelling! Regards, Marc
« Reply #84 on: November 08, 2016, 08:55:32 AM »
Thank you very much, gentlemen.
Now the main rigging is completed, with aileron controls included. But there are still two drag lines missing. Those, however, will be possible to attach only together with side cowling panels as the lines pass through inspection holes.
And the time has come for the engine. As usual, what WNW propose in their kit is decent but there is always some room for amendments. I have noticed the lacking round inspection holes in the front of the crankcase. Some work on it has just started with two slices of a sprue attached. They will be still substantially trimmed down and rings with bolt heads added (probably two pieces from a PE bezel set by HGW will do).
I also plan to add 24 electric wires, a missing water line (?) on the firewall, a few air tubes, oil tank drain, etc. And there must be a fuel supply to the carbs but this is still an enigma for me, as no photo of Rolls Royce Falcon mounted in a Brisfit which I consulted shows these fuel lines clearly. Any help here would be more than welcome!
« Last Edit: October 12, 2017, 10:11:42 PM by PrzemoL »
Offline steveb
« Reply #85 on: November 08, 2016, 12:58:18 PM »
Looks great! So quickly, too!
« Reply #86 on: November 08, 2016, 07:00:22 PM »
Thanks, Steve.
Quickly you say? Well, once everything was prepared, the assembly really goes quick. But those preparations were almost killing me.
Offline eclarson
« Reply #87 on: November 09, 2016, 02:33:12 AM »
Terrific job as always!  May I ask what you used for the rigging?
Eric
« Reply #88 on: November 09, 2016, 03:12:47 AM »
Have not dropped in recently and this model seems to be nearly complete! As usual you are making a superb rendition of the original - your attention to detail is terrific - "just a few extra details to the engine compartment….." Good understatement if ever I read one!!
« Reply #89 on: November 09, 2016, 05:36:06 AM »
Thank you, senhores.
Krow, now I remember admiring your amazing Biff some time ago. Thank you for the heads up, WNW truly misplaced the spark plugs location. I think I will redo them to the correct locations, more off the cylinder blocks axes. The more I look at the photos, the more missing bits emerge. It is not going to be a quick build.
