Author Topic: Modeling tip  (Read 3313 times)
Offline jknaus
Modeling tip
« on: September 14, 2016, 07:00:44 AM »
I am not sure where to put this so forgive me if its in the wrong place.
With kids going back to school (at least in North America) I thought this might be a timely hint. If you buy the Bic Gel Pens
you will find they have a little protective knob on the end. It has to be removed before you can write. I have found these knobs to be of great use as shift knobs, throttle lever knobs etc for aircraft and vehicles. They are round and have an indent where the whire or rod can be inserted and glued/ Much more uniform than glue blobs and easy to paint. I know at least here the local stores have tons of them cheap for the new school year.
Hope that is of some use to someone out there.
James
Online lcarroll
Re: Modeling tip
« Reply #1 on: September 14, 2016, 08:10:03 AM »
Fine idea James, and I have "tossed' my share of them, drat! I think I'll venture down to "Wally Market" tomorrow and get a pak for my Nieuport throttle assembly. :)
Offline jknaus
Re: Modeling tip
« Reply #2 on: September 14, 2016, 09:20:40 AM »
They are handy. Used them to make the knob on the gear shift in my trucks, jeeps etc. Also on some WWII throttles and levers like the belt tension adjust lever on a bang seat.
James
Re: Modeling tip
« Reply #3 on: September 14, 2016, 09:53:42 AM »
What a lovely idea ! Would these work for the smaller scales ? Or are these only suited for large scale ?
Offline jknaus
Re: Modeling tip
« Reply #4 on: September 14, 2016, 10:41:16 AM »
I've used them in 1/48, 1/35, and 1/32. Not sure if it would be over scale in smaller, but that's something you would have to try. Be interesting to know.
James
Re: Modeling tip
« Reply #5 on: September 15, 2016, 06:04:55 AM »
Thanks for the idea, James. I'm always on the lookout for useful bits and pieces like this.
Re: Modeling tip
« Reply #6 on: September 15, 2016, 09:13:54 AM »
James
Thanks James , mostly working in 48 and 32 scale ...Perfect ! PE levers and such I rather not use but also have troubles making a round ball .
Thanks again James  :)
Offline jknaus
Re: Modeling tip
« Reply #7 on: September 15, 2016, 12:10:14 PM »
Tack or Map pins from a sewing shop or map shop also work well if you need different sizes. Hope that helps some more :)
James
Re: Modeling tip
« Reply #8 on: September 15, 2016, 03:53:43 PM »
Nice tips, thank you.
