Author Topic: Hobbycraft 1:32 Scale Nieuport 17- Capt W.A. "Billy" Bishop V.C.  (Read 56549 times)
Re: Hobbycraft 1:32 Scale Nieuport 17- Capt W.A. "Billy" Bishop V.C.
« Reply #135 on: November 01, 2016, 12:22:50 PM »
Tug,
    Just returned after being away since Friday. Just before leaving I sprayed some Alclad II on the forward metal cowlings for some contrast, will try to get some photos on here tomorrow. I've seen the AK Extreme but never tried it, it was very impressive on a contemporary all natural finish jet on display at a contest. (IIRC it won a Gold in class) I intend to get a small selection and give it a try.
« Reply #136 on: November 01, 2016, 07:59:59 PM »
Having done the same kit some time ago, and used the Mastercaster set I follow your build Lance, it's very interesting, the work you did so far is AA class!
« Reply #137 on: November 02, 2016, 12:36:41 AM »
Antonio,
    I used your Build and several others to help along the way, very useful Thread and Thank You!
« Reply #138 on: November 02, 2016, 07:42:11 AM »
    Here's the promised photos of the Alclad II Aircraft Aluminum sprayed on the metal portions of the cowling and upper deck area, some subtle contrast added. I'll be doing the panel/access covers in another shade as well before getting at the weathering and shading  and the final clear and possibly filter coats.
   A little better contrast in this light:
    The Machro Photo mode really shows the imperfections in the wing/fuselage join area; that "perfect model" has again eluded me!!
« Reply #139 on: November 10, 2016, 07:03:54 AM »
Pilot needs a haircut........
« Reply #140 on: November 10, 2016, 07:18:23 AM »
The contrast looks to be just right! Not too much but also not to little!
« Reply #141 on: November 10, 2016, 08:30:56 AM »
Steve,
   I needed a little levity! ;D ;D ;D ;)
« Reply #142 on: November 10, 2016, 08:34:51 AM »
Rick,
   Thanks, it is pretty subtle, I'm presently working on some post shading including the ribs, very slow going and lots of "remove and try a second (or third!) time. I hope to post some photos soon.
« Reply #143 on: November 10, 2016, 09:39:58 AM »
 Lance,
Ah the curse of aluminum paint. This stuff can be a real buzz killer showing up the slightest of imperfections. From your photographs I believe it's an issue that can be rectified easily enough. But surely is a pain with touch up. I very much appreciate the subtle contrast between the two shades of aluminum. Well Done Lance. Keep up the excellent work. Looking forward to more!
« Reply #144 on: November 10, 2016, 12:19:43 PM »
   Thanks for commenting Greg, much appreciated. An aluminum finish is definitely the most revealing of all, and the wing roots on this one are no exception! I'm hoping the shading and markings will do a lot to draw the eyes away from those locations, hope I can get some photos onto here tomorrow.
« Reply #145 on: November 10, 2016, 03:28:56 PM »
I really like your silver dope, Lance, very nice. I think the wingroots are nothing that will still be visible after a treatment with oils when you copy the castor oil thrown by the rotary engine. Seriously, nothing to care about!
« Reply #146 on: November 11, 2016, 12:33:46 AM »
Thanks Borsos. You have a good point; I need to get back to the references before I start throwing oil at it but it will cover a lot of "sins".
« Reply #147 on: November 12, 2016, 01:28:29 AM »
     The post shading of the control and flying surfaces is complete. I used chalk dry pastels in the standard method and toned down the shading with lots of wet cloth rubs. I may add a very light coat of a grey filter to tone it down further but will see how it "sits" with me after a day or two.
     Here's the masking stage, always such a relaxing phase!
......  and the finished products:
     I also completed a few of the miscellaneous bits, the "V" struts with tapes from Tamiya Masking Tape and the cowl with Bishops trademark blue colouring lightly "chipped" using the hairspray technique. I had decaled the rudder earlier but I wasn't happy with the results so it was stripped and masked/painted. Model Master enamels "Blue Angel Blue" and Insignia Red match the Roundel Colours perfectly.
    Starting to fall together now, it's almost time to put the upper wing and landing gear on. Once the shading is sealed I'll start to throw a little oil and grime on her and she'll be ready for assembly.
« Reply #148 on: November 12, 2016, 01:35:51 AM »
Simply Gorgeous results on the post shading Lance. The cowling and markings are also terrific!
« Reply #149 on: November 12, 2016, 01:47:20 AM »
Wow, outstanding.  Looking forward to this one progressing.  Awesome.
« Last Edit: November 12, 2016, 03:28:54 AM by Juan »
