Author Topic: 1:32 Scale Academy Sopwith Camel  (Read 4622 times)
Offline otterine
    • otterine's miniatures
« on: September 02, 2012, 08:49:22 AM »
I build 1:12 scale dollhouses as a main hobby and belong to a forum that holds a kit build contest every year.  We all build the same kit and can do whatever we want with that kit.  This year, my idea called for a WWI airplane replica, and I chose the 1:32 scale Academy Sopwith Camel.  I can't reveal the whole build just yet since I haven't published it yet, but I will be doing so sometime this weekend.
But, I have published the Sopwith Camel build.  I did very few modifications, using the base kit as is but put my painting and aging expertise to work.  The shiny red nose turned out so well, I couldn't bring myself to age it or dirty it in any way.  I did the same wood grain finish on the interior walls, floor and dash based on the various models I had seen other modelers build.    I used black and brown acrylic washes to tone down the shiny new finishes.  The instruments were first painted with a toothpick to fill in the black background.  I then used a sewing pin to paint the instrument details using Liquitex Iridescent Bronze acrylic paint.
I had read that the guns were molded upside down in this kit, but with my shortened build timeline and the fact that I really didn't want to start deconstructing parts, I used the guns as is.  My model wouldn't be the most accurate besides, and it would have been a lot of work for a minor payoff.
For the rigging, I basically used the kit method, though I used black "transparent" thread instead of the kit supplied black fiber thread.  I also waited until after the plane was assembled to add the lines.  I didn't see how you could add the lines during the body assembly, then keep them out of the way and clean during the painting process.  This meant a bit more headache in the end, but it worked out well.
I mostly just used super glue gel to hold the wires in place in the predrilled kit holes.  For the ones in the body, I cut small lengths of brass wire and slipped them into the holes with the wires.  This plugged the hole and held the wire more securely. I dabbed black paint on them later to remove the obvious brass shine.
I made one substitution during the rigging process.  There was supposed to be a straight wire from the bottom of the plane running perpendicular to the wheel assembly.  I knew there would be no way to get the tension correct, so I used a cut off head pin.  It doesn't look like a substitution at first glance and it added stability to wheels besides.
The decals were not the easiest things to deal with, and I admit to being out of practice using them.  But, the end result was pretty good and this was meant to be a weathered replica, so any imperfections actually worked to my advantage.  I followed most of the recommended placements and others I made up from the available decals...like the triangle with a logo in it.
The sign verbiage is taken from the Wikipedia article on the Sopwith Camel.  I printed it on paper, pasted it onto a primed wood scrap and staked it into the ground with some wire.
I'm not sure if the image attachments will work, but you can see more of my build here: http://www.otterine.com/blog/blog1.php/1-32-scale-academy-sopwith
I am in love with my Sopwith Camel!!!!  :D
Brae
Offline otterine
Re: 1:32 Scale Academy Sopwith Camel
« Reply #1 on: September 02, 2012, 08:50:20 AM »
More...
« Last Edit: September 02, 2012, 08:52:00 AM by otterine »
Offline otterine
« Reply #2 on: September 02, 2012, 08:51:22 AM »
and more...
« Reply #3 on: September 02, 2012, 10:28:00 AM »
Very nicely done Brae, it is a very attractive looking model and your build log is excellent. Having built this model not long ago I can appreciate the efforts you have put into it, well done.
Offline otterine
« Reply #4 on: September 02, 2012, 10:34:56 AM »
Thank you so much!  It was just the right amount of challenge for me.
Brae
« Reply #5 on: September 02, 2012, 10:47:11 AM »
   Brae,
Well done my friend. She looks wonderful and well build and painted.
« Reply #6 on: September 02, 2012, 07:26:04 PM »
Looks great, Brae,
Well done!  ;)
BVB
« Reply #7 on: September 02, 2012, 10:26:58 PM »
Absolutely brilliant, Brae!  Truly superb painting and weathering.  To look at her, I'd swear you had been building WWI model aeroplane's all your life.
Offline otterine
« Reply #8 on: September 02, 2012, 10:45:01 PM »
Thank you all so much!  Your compliments mean the world to me!   :D
Brae
Offline Epeeman
« Reply #9 on: September 02, 2012, 11:21:02 PM »
Brae,
Echo what others have said - good one!!
« Reply #10 on: September 03, 2012, 10:13:29 AM »
Brae,
   Very nice, and you say you're a beginner!!?! Let's see more soon.
Cheers and again, welcome,
Offline otterine
« Reply #11 on: September 03, 2012, 10:17:15 AM »
Thank you, thank you!  Yes, this was my first airplane and first biplane.  :D
Brae
Offline Dal Gavan
« Reply #12 on: September 03, 2012, 04:50:03 PM »
I'll echo the others, Brae.  What's your next one going to be?   :)
Dal.
« Reply #13 on: September 03, 2012, 10:35:52 PM »
Your first aircraft model? Well done indeed!
Offline otterine
« Reply #14 on: September 03, 2012, 11:34:42 PM »
Thank you!  I've posted my full build in the dioramas section.
Brae
