Author Topic: Encore Fokker F1 103/17 Triplane and WNW SE5a (Duel) build: Plus MvR Dr1  (Read 157695 times)
Re: Encore Fokker F1 103/17 Triplane and WNW SE5a (Duel) build: Plus MvR Dr1
« Reply #180 on: November 19, 2016, 08:13:34 AM »
I would also jump in with a big like with what the streaking on your F1 finish.
« Reply #181 on: November 19, 2016, 10:09:16 AM »
Extraordinary streaking, Amigo! The colors you've chosen are perfect, imho, and your technique is flawless.  McCudden's report of the engagement in which Voss was killed stated that he flew a "silver" plane, which this would look like at a distance.  Well done!
Thanks Amigo! McCuddens Silvery Blue description and GvW opinion swayed me to use the blue base. OD over blue does lend itself to a Silvery /greyish look, at least In My Opinion  8)
Great streaking Rick, the insignia and other decals are really going to bring this to life..
I can't see a crack?  I guess you are like me - in that if you know something is there, you want to fix it?  But in photos and when viewed on your shelf will you see it??
I still have a few more Dr1s in my stash and I have yet to try streaking, but this looks really good!
Thanks for the comments Ian. The crack is there and as tempting as it is to just let it go I won't! Not too difficult to fix once the oils dry and I give a gloss coat to allow me to mask the areas I don't want to re do!
Now that is how I've always imagined the F1 streaking looked.
Tony.
Thanks For looking in and the very positive comment Tony! Greatly Appreciated! I have used the attached photo and a couple of others from GvWs' Fokker DR1 Jadgestaffeln book. I pulled this photo off of the net so if there is any copyright issue I will of course be happy to remove the photo.
Thanks Juan. I really appreciate you checking in and commenting!
« Last Edit: April 14, 2018, 11:25:35 PM by RAGIII »
« Reply #182 on: November 20, 2016, 04:03:16 AM »
I really admire your streaking Rick. Somehow this is a technique that you have down to a very fine finish indeed. When the wings are complete and markings are on this will be a tremendous model.
Offline Suffolk Lad
« Reply #183 on: November 20, 2016, 04:56:27 AM »
Time was if you were considered a great 'streaker' you wouldn't have been making models that's for sure  ;D
But times have changed and the whole thing now has a totally different meaning and you deserve the title Rick - truly, as others have said, a stunning result indeed  :)
Tug
Offline jeroen_R90S
« Reply #184 on: November 20, 2016, 06:42:44 AM »
The model gives the same impression as the example on the picture -great work! Those white cross fields will show off nicely :)
« Reply #185 on: November 20, 2016, 10:02:06 AM »
Thanks Stephen. Greatly appreciate your comments!
Tug
LOL! Yes back in the early Seventies I think it would have been totally different  ::) I do appreciate the positive feedback!
Thank You. I try to give as close to the streaked footprint as I can  8)
« Reply #186 on: November 20, 2016, 11:41:17 AM »
Very nice! The Erica Roe of Fokkers!
« Reply #187 on: November 20, 2016, 12:34:48 PM »
Thanks Ian. I had to google Erica Roe  ;D
Offline Ian from Doncaster
« Reply #188 on: November 20, 2016, 07:39:18 PM »
So now you know why British policemen hve helmets shaped like that!! if you saw the right picture from the newspaper that is.. if not, you'll have no idea what I am on about!
« Reply #189 on: November 21, 2016, 05:38:57 AM »
Gloss coat on the SE5a and F1.
Now to apply strippers.
« Last Edit: April 14, 2018, 11:26:39 PM by RAGIII »
« Reply #190 on: November 21, 2016, 06:28:40 PM »
Great art, you show here, the streaking of the Fokker is outstanding and the Se will be terrific, too.
Cheers,Manni
« Reply #191 on: November 22, 2016, 05:59:38 AM »
Cheers,Manni
Thanks Manni!
« Reply #192 on: December 03, 2016, 02:59:11 AM »
A mini update: I have applied the markings. The upper wing cross fields were painted as the ones supplied were too narrow and designed to fit the late style aileron ! The fuselage crosses/white fields were the kit decals, as are the F1 103/17 markings.
« Last Edit: April 14, 2018, 11:27:13 PM by RAGIII »
« Reply #193 on: December 03, 2016, 03:32:10 AM »
Wow, Rick, have you ever "aced" that striping effect, very very nice! Following your Build makes me want to dig mine out and get right at it, but I guess I should finish up my W.12 first, only take me a few days I'm sure! ::)
Keep at her, she's a real beauty!
Offline Suffolk Lad
« Reply #194 on: December 03, 2016, 04:10:45 AM »
Perfect rendition Rick - just perfect. As Lance you are giving me too many ideas  :-\
Great result to date - this is going to be a stunning triple all round  :)
Regards - Tug
