Author Topic: tension...  (Read 11040 times)
mike in calif
tension...
« on: August 22, 2012, 09:25:32 AM »
What are some ways to keep a reletive amount of tension on rigging, and structural wires? I have some EZ line, and some .006 thous. wire. I've started a DH-9a, and need to rig the rudder bars/ rudder wires together, as well as the structural wires for the frame. In studying the drawings, I see also a "skid control wire". Is the tail skid steerable?
Re: tension...
« Reply #1 on: August 23, 2012, 12:40:29 AM »
I employ the monofilament, eyelet and brass tubing methodology for my rigging. I use a hemostat in my left hand to apply tension to the monofilament tail piece and apply a drop of superglue to the brass tubing with my right hand. Works like a charm.
Re: tension...
« Reply #2 on: August 23, 2012, 07:19:13 AM »
I use the same method as Chris, monofilament, eyelets, turnbuckles and small brass tube sleeves. This technique is quite easy to apply and the results are pleasing, please have a look at the link below for my rigging technique.
Some of the earlier aircraft had steerable tail skids.
http://www.ww1aircraftmodels.com/page6.html
Offline Steven Robson
Re: tension...
« Reply #3 on: September 22, 2012, 04:45:24 PM »
Hi
I also use Des' technique, using eyelets, mono and brass sleeves.  This approach is best because:
1) EZ line does not rig to scale, it's a rubber band type of product (there is nothing easy about a product that varies in diameter depending upon the distance it's being stretched).
2) monofilament with eyelets and turnbuckles adds structural integrity to your build
Steven Robson
