Author Topic: Masking fluids are a disappointment  (Read 2614 times)
Offline GHE
« on: June 25, 2016, 11:43:04 PM »
Messieurs,
Building Roden's Fokker Dr.I (1/32) as prototype V4 I made use of Microscale's Fluid Mask during the finishing process of the upper wing areas ( where the linen shows
a triangular pattern on the front of each wing).
It was not possible to peel of the mask without ruining the paint job; parts of the mask would not come off at all. Water did not help to remove the film.
Finally the wings ended  up: build it - bin it.
I'll have to cannibalize a second kit; it is easier to build them anew than to clean off the whole paint job.
kind regards , Gunther
LZeppelin rocks!
Re: Masking fluids are a disappointment
« Reply #1 on: June 26, 2016, 01:10:32 AM »
oh what bad news,
I am not a fan of masking fluids neither. I tried chipping effects by adding masking fluids by a sponge - under a coat of paint it never went off as it should.
I wish you all the best for the fixing of your wing problem!
« Reply #2 on: June 26, 2016, 07:38:51 AM »
Sorry to hear you had issues with the masking fluid, I also have had problems using this product so I binned the remainder of the bottle.
« Reply #3 on: June 28, 2016, 01:42:42 PM »
get some of the product below and an old toothbrush and you can strip your paint easily.
http://www.minutemanscalemodels.com/product-p/10568.htm
« Reply #4 on: June 28, 2016, 08:56:16 PM »
Gunther, I use IPA and a paper towel.  The acrylic paint just wipes off easily.
I never had much luck with the fluid masks and don't bother with
them anymore.
« Reply #5 on: June 28, 2016, 11:23:37 PM »
Just a word about liquid masks. I tried Micro Scale once, NEVER AGAIN! It absolutely lifts any Acrylic paints and is difficult to remove. I have used the following with NO Problem at all on any paints: Magic Masker and Valejo. Just roll them with a finger and they peel right off without lifting paint.
« Reply #6 on: June 29, 2016, 07:28:12 AM »
Thanks Rick for the tip, I will give it a go.
Offline stefanbuss
« Reply #7 on: June 29, 2016, 05:30:56 PM »
Beware: the Valejo masking stuff will remove the coating from anything covered with Future (windshields).
edit: Guess how i came to know that...
« Last Edit: June 29, 2016, 07:30:03 PM by stefanbuss »
Offline markleecarter
« Reply #8 on: June 29, 2016, 06:22:03 PM »
Another vote for the Vallejo stuff. It dries pretty quickly and has always come off cleanly for me.
