Author Topic: RAF Fe.2b 1/32  (Read 3739 times)
Offline Chrupek
RAF Fe.2b 1/32
« on: August 20, 2012, 06:32:08 PM »
Hello!
 Advance warn honorable body that my English leaves much to be desired. I use the Google translator. I'm sorry for any errors!
 This is my first post on this forum and my first WWI plane.
 So far, I built models in 1/32 scale aircraft from WWII period. At the urging of his colleagues tried their hand at aircraft made ​​of wood and rags.
 The choice fell on the Royal Aircraft Factory Farman Experimental Fe.2b in 1/32 of the stable Wingnut Wings. As additives used a set of HGW belts. To perform pulls the tube from purchased Bobsbuckles. Loops have done yourself a tension vein is 0.12 mm. I sincerely hope that you will like the model. Next on my assembly line is Gotha G.IV in 1/32 of the Wingnut Wings Polish painting in 1920 from the Polish-Bolshevik War. In Gotha G.IV elements will be used Taurus Models resin production.
So what? As for the first time probably is not bad?
Marcin Chrupek Chruscielewski
IPMS Silesia/IPMS Polska
Re: RAF Fe.2b 1/32
« Reply #1 on: August 20, 2012, 07:07:53 PM »
A beautiful introduction!
Well done!!!
BVB
Re: RAF Fe.2b 1/32
« Reply #2 on: August 20, 2012, 08:04:24 PM »
Congratulations on building your first WW1 aircraft, you have done a superb job, the rigging looks brilliant I look forward to seeing more of your work posted here soon.
Re: RAF Fe.2b 1/32
« Reply #3 on: August 20, 2012, 10:11:19 PM »
Very nice!  Don't worry, the pictures speak for you!
Re: RAF Fe.2b 1/32
« Reply #4 on: August 20, 2012, 10:19:10 PM »
Very nice! You picked a very complex kit for your first WWI model and with excellent results like this, I'm looking forward to seeing your next project.
Re: RAF Fe.2b 1/32
« Reply #5 on: August 21, 2012, 12:07:00 AM »
  Congradulations my friend on completing your first WW I project. Bravo and well done.
Re: RAF Fe.2b 1/32
« Reply #6 on: August 21, 2012, 01:49:22 AM »
Welcome to the forum, Marcin!  What a spectacular introduction!  As other have said, you picked a tough one for your first WWI aircraft.  It doesn't get more complex than this, but you did a stunning job.  All other WWI aircraft should be easy for you, now.  Even the Gotha.
Offline Epeeman
Re: RAF Fe.2b 1/32
« Reply #7 on: August 21, 2012, 07:13:02 AM »
Brave man taking on this one for your first WW1 build!
Excellent job all round.
Offline MammaAiuto
Re: RAF Fe.2b 1/32
« Reply #8 on: August 21, 2012, 07:19:25 AM »
Hello Chrupek
Very pretty... si si molto buono molto buono un modello molto bello ‹(•¿•)›
I really like your grass, very long and natural .... as for the rest superb introduction.
I will follow your next build with attention
Salut
Marc P.
Offline Whiteknuckles
Re: RAF Fe.2b 1/32
« Reply #9 on: August 21, 2012, 09:40:33 AM »
Hello and welcome Chrupek :)
From what others have said, you picked a formidable bird as your first foray into WW1 modelling - and pulled it off magnificantly ;)
Eternal Apprentice
Re: RAF Fe.2b 1/32
« Reply #10 on: August 22, 2012, 10:45:02 AM »
Absolutely spectacular start Chrupek, your model is supurb. As already said, all others should be easy given the simply great results you have achieved with this beauty!
Cheers, and Welcome here,
TCinLA
Re: RAF Fe.2b 1/32
« Reply #11 on: October 08, 2012, 07:55:27 AM »
Nothing like diving straight into the deep end without knowing how to swim.  I've been doing WW1 models for (mumblemumble) a long time, and rigging the F.E.2b is definitely "skill stretching."   Richard Alexander at WNW says he thinks this kit is more difficult than the Gotha.  I think he's right.
So, for a first attempt to look as really good as this one does is a very high achievement.  Well done!
