Author Topic: 1:32 Scale WNW Pfalz D.XII #2695/18  (Read 44371 times)
Re: 1:32 Scale WNW Pfalz D.XII #2695/18
« Reply #75 on: June 16, 2016, 12:31:14 AM »
Quote
    LOL, of all the things we could accuse von Buckle of supplying "nasty girls" might hurt his feelings a bit! :o I needed a good laugh this morning with my coffee!
Nasty girls always hurt my feelings.... Pure nasty!
von TearoffaStripper   :D
Offline stefanbuss
« Reply #76 on: June 16, 2016, 09:46:25 PM »
Quote
I'll add a photo here once they are done.
Closeups appreciated. Of those strips in use, of course.  8)
« Reply #77 on: June 16, 2016, 11:28:37 PM »
   The lower wing and fuselage have been joined and, after minimal filling with Tamiya White Putty and final filling with Surface Primer it looks about as good as it's going to get.
   The "Bob's Strippers" mentioned earlier have been added and a quick sealer coat of Future applied. Here's a couple of photos as requested by Stefan........
   Now it's time to start masking and finishing the fuselage paint job before tackling the final assembly.
« Reply #78 on: June 16, 2016, 11:37:41 PM »
I'm deeply impressed, Lance, very nice finish on the wings (although I still hope to see those nasty girls...).
What kind of decal softener do you use? I like how those decals went down on the trailing edges!
Borsos
« Reply #79 on: June 17, 2016, 01:10:38 AM »
Borsos
Borsos,
    I use this sparingly on the edges and over high relief details. I've heard it's not as strong as other brands commonly used but it always has worked well for me.
« Reply #80 on: June 17, 2016, 02:24:15 AM »
My sincere apologies Lance, but I have somehow completely missed this one. Having read through you log I can only write that you demonstrate fully all the skills of a master modeller. That join of the lower wing to fuselage is an achievement in itself which many of us lesser modellers could not have done. I will now be following this more closely.
« Reply #81 on: June 17, 2016, 02:45:09 AM »
Lance, thank you! I had used the Micro Set/Sol for many years (it lasted long...) and now have switched to Mr. Softer/Setter for some months. To me it seems quite to the contrary as if the Micro products were a little stronger than the Gunze products. Maybe I'll switch again. For when I used Aviattic's linen decals I had some problems to get them tight around the trailing edges, they did not look as good as your Tarnstoff decals.
Borsos
« Reply #82 on: June 17, 2016, 05:26:52 AM »
Thank you Stephen, coming from a true "Master" your comments are always very much appreciated!
Borsos,
    I was reluctant to use a setting solution on the Aviattic Lozenge however started having the same problem with the edges "lifting", The Microsol seems to have eliminated that problem.
Offline stefanbuss
« Reply #83 on: June 17, 2016, 02:27:12 PM »
Thank you for posting the close-ups. It looks like those strips might be useful as ribtapes on Roden aircraft as well?
Offline łukasz
« Reply #84 on: June 17, 2016, 04:43:27 PM »
fantastic.
glory to the heroes
Offline Dave in Dubai
  • Beyond the blue horizon
« Reply #85 on: June 17, 2016, 10:06:40 PM »
This is looking really good Lance.
I am using the same microsol solution for the trailing edges , it is one of the make or break areas on lozenge covered wings.
Your model is going to look fantastic when completed.
Best wishes,
« Reply #86 on: June 18, 2016, 12:44:37 AM »
Stefan,
    Thats what I bought them for, but have yet to try them for that. I have a Hobby Craft Nieuport 17 that may be the first.
« Reply #87 on: June 18, 2016, 01:08:48 AM »
Lukasz, Dave,
    Many thanks for the comments. The trailing edges are indeed the one area that can pose a problem if not treated. Generally though I find the Aviattic decals go on and work very well.
« Reply #88 on: June 19, 2016, 02:01:28 AM »
Been watching for sometime, can't believe I haven't commented till now, great work, especially on the decals !
« Last Edit: June 19, 2016, 08:14:29 AM by dr 1 ace »
« Reply #89 on: June 19, 2016, 05:10:18 AM »
   Thanks Ed, appreciate you looking and commenting! :)
