Author Topic: Albatros D I 1/32 Roden  (Read 71592 times)
Re: Albatros D I 1/32 Roden
« Reply #90 on: May 05, 2016, 01:59:32 AM »
Gorgeous work on the top decking, Borsos!
« Reply #91 on: May 05, 2016, 04:36:33 AM »
Beautiful work, Borsos, and some really useful tips... pure inspiration! Regards, Marc.
Offline Edo
« Reply #92 on: May 05, 2016, 05:45:17 PM »
Hey Borsos!
you are doing a very good job! As other have already said: truly inspitring!
ciao
edo
« Reply #93 on: May 12, 2016, 06:00:08 PM »
Great, simply great. I love the Interieur.
Manfred
Offline Ssasho0
    • Scale Models Club Bulgaria
« Reply #94 on: May 12, 2016, 06:05:55 PM »
just found that build and catch up - wonderfull and insipiring work!
Think globally, act locally!
« Reply #95 on: May 14, 2016, 09:15:28 AM »
Thank you so much, guys, for your kind words and your support.
After having closed the fuselage I sanded the seems and rescribed the panellines. Then the question rose if the lower wing part should be added right now. I think there are three ways to deal with that area:
1. Adding the whole part. Then fuselage and lower wings are strongly connected and it might become more difficult to work on the fuselage.
2. leaving this part off until having finished the whole detailing and paintjob on the fuselage. In this case the part would have to fit the fuselage perfectly and not show any signs of missalignment.
3. Cutting the middle part, adding this to the fuselage and finishing the fuselage as a whole. Then adding both lower wings by pinning them with brassrod.
For 2. the fitting of this kit isn't good enough and for 3. I was too afraid to weaken the whole affaitr too much, so i opted nolens volens for 1: The fitting really wasn't great and I did a lot of sanding and reworking to get those components together.
After closing a fuselage I always want to check, how the finished plane would look like and if every main component fits the model. I hate bad surprises when a paintjob is finished. To add more strength to the kit I replaced the interplane struts with brass tube, where I inserted a thinner brassrod and soldered the joints. A very similar method I chose for the landing gear, I did not want to place such a heavy model on tiny plastic struts...
The upper wing and the lower wing were bent. I realized that after tryfitting the wings. I needed some time with a hairdryer and some unrepeatable words which are not for children's ears (I hate bent wings...) before both wings were straight. It seems like I had got a bad copy of the Roden kit, because the same parts in the Encore Albatros D II, that shares the plastic parts with this kit,  were wonderfully straight.
Thanks to the well enginered and perfectly fitting cabane struts, the whole strut affair on the Albatros D I is pretty simple.
The fitting of the rest of the main Parts isn't bad neither.
I like the overall appearance of that kit, it really looks like an Albatros. Now it has to go on with detailing and painting the main subassemblies. Let's hope that it still looks like an Albatros after this ...
Thank you
Borsos
« Last Edit: March 30, 2018, 05:23:53 PM by Borsos »
« Reply #96 on: May 14, 2016, 09:28:55 AM »
You are doing a superb job with this Roden kit Borsos and it certainly is looking like an Albatros.
« Reply #97 on: May 14, 2016, 09:47:56 AM »
Borsos,
   This is really coming along nicely, it's going to be a beautiful model. I'm impressed with your inter-plane struts; is that pre-formed "Strutz" Product or did you flatten it yourself? Either way it's very nicely done. I have the Encore DII as well and will have to check those wings!
« Reply #98 on: May 14, 2016, 10:51:45 AM »
Borsos,
Borsos, Lance asked my question about the interplane struts.  Looks like a neat technique.  In any
regard, the Alby is certainly shaping up nicely, despite the little wing problem.  Well done, my friend.
« Reply #99 on: May 14, 2016, 12:17:44 PM »
Borsos,
Your Albatros continues to be an inspiring and beautiful build! The struts are perfect. Nice work on flattening out those wings!
Offline moustique
« Reply #100 on: May 15, 2016, 01:03:53 AM »
great job
this albatros is fabulous
« Reply #101 on: May 15, 2016, 12:27:04 PM »
 Borsos,
Outstanding project my friend. I'm glad to see the Roden kit being so expertly constructed. Your thread is a most excellent reference for anyone building up a Albatros D.I. Well done and keep up the outstanding progress.
Offline stefanbuss
« Reply #102 on: May 16, 2016, 04:05:50 AM »
Neat idea with those brass rods - would like to learn the method you used with a little bit more detail, like the others that have asked.
S.
« Reply #103 on: May 16, 2016, 09:38:26 AM »
i like your progress. very nice work on this classic kit
« Reply #104 on: May 17, 2016, 11:50:42 PM »
Hello friends,
Thank you all for your support, and a special thank to Bertl, your Pics are extremely valuable for my built (I even realized that I trapped into a trap that I had dig myself, but more on this later)...
Of course I can show you the way I do my struts. These are no preformed "strutz" material, because I read much about it and had searched the internet for it several times but never got my hands on this stuff. Anyway, there's another way:
This is an inconspicious but valuable tool that I had bought some years ago from Albion Alloys. It's called "the strutter":
Edit: I add here a link to Richards MS L build, where this technique was discussed some times later:
https://forum.ww1aircraftmodels.com/index.php?topic=8340.0
then I solder the ends (to connect rod and tube) and sand it down. That's it: very strong struts.
And here's the other occasion when I use this tool: squeezing veneer for carving props...
Thank you!
Borsos
« Last Edit: April 01, 2018, 11:29:22 PM by Borsos »
