Author Topic: Albatros D I 1/32 Roden  (Read 71707 times)
Re: Albatros D I 1/32 Roden
« Reply #120 on: May 24, 2016, 07:16:06 PM »
Ah, yes.
It is looking very nice. Hmm...Drooling Bulldog. Completely unknown in Germany I think.
« Reply #121 on: May 24, 2016, 07:39:09 PM »
Excellent work painting the wings Borsos, the blue is very attractive.
« Reply #122 on: May 24, 2016, 09:31:39 PM »
I think drooling bulldog is mainly marketed to this forum.the designers are members here and news posted regularly.
To borsos I salute you.very nice paint work
« Reply #123 on: May 24, 2016, 10:57:00 PM »
Beautiful painting ! You are certainly inspiring me not only to build an Albatros but to get the Drooling Bulldog colors!
Offline BigBlue
« Reply #124 on: May 25, 2016, 12:23:46 AM »
Gorgeous!!
« Reply #125 on: May 25, 2016, 01:25:42 AM »
Simply stunning paint work, Andreas!  Really looking forward to your next update.  Are you using Drooling Bulldog on the upper surfaces as well?  I'll have to order some of these.
Offline stefanbuss
« Reply #126 on: May 30, 2016, 03:56:12 PM »
Quote
and toning down the effect a bit
How did you do that?
S.
« Reply #127 on: May 31, 2016, 11:49:06 PM »
Hello,
sorry for my late reply and again thank you very much for your kind comments!
Quote
Yes, Bud, I use these Drooling Bulldog Colors for the upper camouflage as well. When it comes to the colors I followed "The Camouflage and Markings of the Albatros D.II Aircraft" by Dan-San Abbott (http://www.theaerodrome.com/forum/showthread.php?t=26276), that means I used three tones: a dark, olive green, a light green and a red, "Venetian"
brown. Regarding the exact pattern I interpreted the pics in the WDF 100.
This time I wasn't too convinced about the Color shade (or I used the wrong Colors?) For the light green I used "blaßgrün" - too dark in my opinion, and for the venetian red neither "caput mortuum" nor "raw Umber" seemed to fit the tone I had in mind and in the end I used Revell 37. For the olive green I used "olivgrün" - a Little bit on the dark side for me too.
So I repainted the wings and added some yellow and white to the "blaßgrün" and to the olive green. Now I liked it much better.
I stored my mixed Colors in some old cleaned bottles that i always use for my own mixes. One of the bottles was made of plastic... The next day I found the plastic bottle melted by the paint. Well, it's enamel and I had just used acrylics for the last about 8 years... I felt sad for the pretty Color and had no mixed spare paint now to touch up any possible faults... :(
The Roden decals are famous for being awfull and these here sadly were no exception. I would have had to stop this tragedy before the decals stuck too well on the painted white fields.
Painted crosses for the undersides...
Shadowing again with Mr Color smoke; then normally I would again tone down this effect...
Quote
Stephan, I tone down the shadows by overspraying the shadowed wing with diluted blue/Brown/green Color. But as I had no light green here any more, I couldn't tone down the whole affair on the upper wings...
Next Step: Prepairing the fuselage for the Wood decals. That meant preshading
Overspraying with diluted Mr. Color "random"
lightening up with white
and overpainting again every wooden Panel in a slightly different shade
(that takes ist time since it's better to leave the Colors enough time to dry before masking them).
So much for now - as always any comments, critics, questions are welcome!
Thank you
Borsos
P. S.: Manni, you can find the Drooling Bulldog paints here, if you like them:http://www.droolingbulldog.com/ (I have no Connection to the seller, I am just a happy customer ... with a melted plastic bottle...)
« Last Edit: April 01, 2018, 11:39:59 PM by Borsos »
« Reply #128 on: June 01, 2016, 12:01:14 AM »
The upper surface colors look terrific! I am so happy they will soon be available through a US distributer! Your pre shading and artistic approach is terrific also!
Offline kornbeef
« Reply #129 on: June 01, 2016, 02:21:46 AM »
Wonderful work, nice recovery on the decals too, I can't wait to see the wood take shape, from what I see so far it's going to look wonderful.
Keith
« Reply #130 on: June 01, 2016, 02:46:57 AM »
   Great colours on the wings, Borsos, and the wood fuselage is going to be spectacular. The Drooling Bulldog paints are looking more interesting every time I see them; I'll have to get and try a few samples when the North American source becomes available.
« Reply #131 on: June 01, 2016, 02:58:27 AM »
Magnificent work, Andreas!  The painted crosses look amazing as does your shading.  The DB colors look fantastic and I'll definitely use them on subsequent Albarosen.  Very much looking forward to your application of Uschi's decals.
« Reply #132 on: June 01, 2016, 09:06:10 AM »
Thank you all!
I had to go on with the fuselage tonight, I am very curious too how the wood decals will look on it.
On the metal parts of the engine cover you can see a large metallic patch: Although I had avoided to use hairspray and had used Migs Chipping fluid that contrary to normal hairspray should harden some days after using and build up a strong connection between the two layers of paint it separates, when I removed the masking tape, the connection between aluminium and green was not strong enough here  :(
The fuselage looks quite patchy, but it has to, because the decals will soften the contrast between the wooden panels.
The first decal  :) :
Kind regards
Borsos
« Last Edit: April 01, 2018, 11:42:10 PM by Borsos »
Offline BigBlue
« Reply #133 on: June 01, 2016, 12:53:48 PM »
Oh that is going to look terrific, Borsos!  Sorry to hear about the mishap, but despite the inconvenience, I am sure that repair will pose little challenge to you.
Offline stefanbuss
« Reply #134 on: June 01, 2016, 05:45:17 PM »
Are you going to add the valves on the fuselage's belly at a later stage, or are you going to leave them off?
S.
