Author Topic: Manfred von Richthofen's E.III WnW  (Read 6413 times)
« on: March 13, 2016, 03:17:19 PM »
Good day everyone,
This is WnW's Fokker E.III done to represent the aircraft flown by Manfred von Richthofen in his early days as a scout pilot. I used the same old figure from Model Cellar (seen previously with my LVG C.IV) to pose beside it to give a size perspective in a couple of the pics.
« Last Edit: March 13, 2016, 06:05:16 PM by gedmundson »
Offline Dave Brewer
Re: Manfred von Richtofen's E.III WnW
« Reply #1 on: March 13, 2016, 03:50:28 PM »
That's absolutely lovely Gary,the machined metal effect is most impressive,as is the weathering.I particularly like the two posed shots.
« Reply #2 on: March 13, 2016, 04:59:29 PM »
Great job Gary,
I particularly like the last 2 shots too  ;) cracking!
What is the background you use?
« Reply #3 on: March 13, 2016, 05:29:54 PM »
Extremely well done Gary, the overall finish on the Fokker is superb and the background is excellent.
Offline boggie
Re: Manfred von Richthofen's E.III WnW
« Reply #4 on: March 13, 2016, 07:25:11 PM »
Great squiggly work Gary!
I very much like your oil staining and that prop really is excellent.
A model to be very proud of.
Whats next?  :)
« Reply #5 on: March 13, 2016, 09:26:21 PM »
The Eindecker is an absolute stunner, Gary!  I really like the
setting with the figure and background...it completes everything
beautifully.  I have to ask how you did the "squiggles" on the
aluminum parts?  Superb model, my friend!
Offline dtomko
« Reply #6 on: March 13, 2016, 09:47:39 PM »
Fantastic job!  That's a beautiful finish.
Drew
Offline Oeli
« Reply #7 on: March 13, 2016, 10:34:56 PM »
Hi Gary,
wonderful work! :)
It´s looking beautiful, and the discreetly weathering, great!
Jörg
Offline Suffolk Lad
« Reply #8 on: March 13, 2016, 10:53:12 PM »
That's absolutely gorgeous Gary - those last two pics make it especially so.  I have just received this kit but to date had dismissed doing a 'grey' version - your's has certainly focussed my mind some - beautiful work indeed.
Regards - Tug
« Reply #9 on: March 13, 2016, 11:09:23 PM »
    Wow Gary, you didn't hold back on this one! I really like the shading you've done and the rigging is impressive to say the least, GasPatch 1:48 Buckles? Also would like to know more about the grass base she's sitting on in the last two photos, locally sourced?
    Great detail and finish as we've come to expect from your bench, nicely done!
« Reply #10 on: March 13, 2016, 11:28:33 PM »
I am in awe of the weathering! I absolutely LOVE the soaked in oil look around the ribs and fuselage formers. How did you do that? Beautiful all around and the rigging is awesome!
« Reply #11 on: March 13, 2016, 11:58:12 PM »
Thanks Gentlemen - glad you like the model.
Guy - you asked about the background I've used. It's a printed model train backdrop from FALLER, and is about 3' X 1.5' drymounted on a piece of foam board. The colours get a bit washed out since I use four floodlamps to illuminate the subject.
Boggie asked - what I'll be doing next? Well - I've got a couple more WnW on the go; a Pfalz D.XII and a D.IIIa. I'm still waiting for some help from Bertl as to how he got that wonderful weathered black finish on his D.IIIa
Ernie asked about the turned aluminum squiggles. That was the one thing that held this project up for months - trying to figure out how to do that without having the types of paints recommended in the WnW helpful tips on their website. I experimented with various metal finishes, finally settling on a base of Alclad Dark Aluminum, and using a new 000 brush to paint squiggles of Testor Model Master Chrome Silver on the surface. The interior of the aluminum cowlings were done with other combinations as I worked out the process since they are barely visible. I also sprayed a few light lines of Tamiya Smoke here and there to weather the surface.
Tug - I had also not wanted to do that greyish green scheme originally, but trusted the WnW reference team since I was wanting to do MvR's mount. As a compromise, halfway through this project I bought another WnW Eindecker II/III just so I could build a cream-coloured one. To be honest for this project I mixed a lighter shade of the XF-22 they suggest by adding some XF-60 Dark Yellow.
Lance, you are always too kind! The turnbuckles are the photo-etched ones from RB Productions. I tried to use a translucent metal enamel on them just to tone down the bright brass look. The base is an old trophy plaque that I just added some Celuclay (with acrylic paint for colour), and randomly stuck static grass of various colours here and there. I've made similar bases for my armour projects for years, and was able to throw that together quickly. It's big enough to work for most of the WnW projects I've built so far.
And RAGIII - Thanks! I pre-shaded the fuselage ribs and the cross-wires above the rear fuel tank, then added very thin masking tape to all these spots. After spraying on the base colour, I removed the tape, then added more base colour to blend and fade the harsh lines. I also airbrushed a very dark brown to show where oil had soaked into the fabric, and later added little cumulative dots of diluted oil paint around these same areas to simulate the stains seen in a lot of the period photos. The wings were done in the same fashion.
Cheers!
« Reply #12 on: March 14, 2016, 01:16:22 AM »
Lovely work, Gary. It looks very impressive.
« Reply #13 on: March 14, 2016, 02:29:29 AM »
Magnificent Eindecker, Gary!  One of the finest I've seen.
« Reply #14 on: March 14, 2016, 02:35:35 AM »
Add another admirer to the mix... Super job, Gary  ;)
vB
