Author Topic: Roden's 1/32 S.E.5a (Wollseley Viper) - Grinnell-Milne's 'Schweinhund'  (Read 61434 times)
Re: Roden's 1/32 S.E.5a (Wollseley Viper) - Grinnell-Milne's 'Schweinhund'
« Reply #60 on: April 26, 2012, 02:32:54 AM »
  Chris,
Great job on the Viper my friend.
Thanks Gregory!
« Reply #61 on: April 26, 2012, 03:03:27 PM »
its really hard to believe youve only done a handful of biplanes. cudos to you my friend you got some modelling skills.
Offline Flyjunkie
  • wherever You go, there You are...
« Reply #62 on: April 26, 2012, 03:11:07 PM »
Great looking motor. Now the only fear is the dreaded Roden engine to fuselage fit. Why did they name their company after a giant Japanese rubber flying chicken? Toko was so bad?
Technically It's RODAN not Roden..
RODAN is the flying Monster of Godzilla film fame... Roden is the Czech model company... ;) ;D
« Last Edit: April 26, 2012, 03:14:25 PM by Flyjunkie »
"..Buy the Ticket, Take the Ride.." ~~ Hunter S. Thompson
« Reply #63 on: April 26, 2012, 09:57:32 PM »
I couldn't do any of this without guys like you giving tips and advice along the way. I'm still climbing that learning curve.
Offline keith_christie
« Reply #64 on: April 26, 2012, 10:57:54 PM »
Really nice progress on this one Chris,
The engine and the wings look very nice indeed.
Best Regards
Keith
« Reply #65 on: April 27, 2012, 12:09:53 AM »
Best Regards
Keith
Thanks Keith. I look at your LVG C.VI and I see where I'd like to be in terms of craftsmanship, so I work away at trying to get better with each of my builds. This one is proving to be particularly trying though, and I can't help but think that I've fallen back a step or two!
« Reply #66 on: April 27, 2012, 02:36:27 AM »
Best Regards
Keith
Thanks for the kind words Chris, I'm looking forward to seeing you progress with this
Best Regards
Keith
« Reply #67 on: April 27, 2012, 08:18:38 AM »
Chris, Really nice work on the Vper engine! Looks fantastic!!
« Reply #68 on: April 27, 2012, 08:35:37 AM »
Thanks RAGIII. I'm rapidly approaching the time where I'll find out just how bad the fit issues are for it in the fuselage.  :o
« Reply #69 on: April 28, 2012, 04:40:32 AM »
I've got the woodwork done on 'Schweinhund' at this point in the build, and now I'm trying to figure out how the cockpit goes together.
I airbrushed Tamiya Deck Tan on all of the woodgrain parts first and followed that with a streaked wash of Burnt Sienna oil paint. When that was dry, I brushed on a thinned coat of Tamiya's Clear Yellow. Lastly, I sealed it all with a coat of Satin clear coat.
Roden doesn't supply any instrument decals so I used some from Airscale's 'WWI Instrument Dial Decal' sheet. The molded bezels were painted with Humbrol's 'Brass' and Vallejo's 'Old Gold'. I clear coated each dial with 'Future'.
In both the image above and below, you'll see that I added cockpit bracing. It's made from 0.10" lead wire and brass tubing for turnbuckles. It looks overscale and that's my intention. When the fuselage is buttoned up, there's not much light inside the cockpit, and the view is restricted, so I wanted the bracing to stand out a bit. It seems to me that 2lb monofilament bracing gets lost inside a dark, busy cockpit. The downside is that it's difficult to pull lead wire taut.  :(
The following images are of the finished struts and propeller.
In regards to the propeller, I haven't added the laminations that are so apparent on German aircraft propellers. I think I read somewhere that the laminates for British props were very similar in colour so it's not necessary to show contrasting laminations. Is that correct, or should I think about showing laminations?
Thanks for looking!
Offline phs Paddy
« Reply #70 on: April 28, 2012, 04:59:20 AM »
Beautiful Chris! Love your wood graining throughout. The grain looks very scale to me. The IP is top drawer also. She's going to be a grand machine.
Paddy
P.S. When brushing the Tam Clear Yellow what do you thin with and the ratio if you don't mind?
« Last Edit: April 28, 2012, 05:04:53 AM by phs Paddy »
« Reply #71 on: April 28, 2012, 06:07:11 AM »
   Chris ,
Outstanding interior my old friend. Absoluely beautiful wood work, so much so it actually looks like you've used real wood.The same applies to the landing struts and prop. A tip for you,when you use wire for riggingit works best if you roll it first on a hard surface while pressing down with a book. I roll mine on the glass covering my bench.
« Reply #72 on: April 28, 2012, 09:14:50 AM »
Re propeller laminations; not all german props had the highly contrasting laminations that are often modelled. Axial props, in particularly, often appear to be a uniform colour similar to british ones. I'd be inclined to add laminations if you have a period photo of the particular aircraft that supports it, otherwise not.
I'll look through some of my refs again to see what S.E.5a props look like and then make my decision. I kinda' like it the way it is though so it'll take a photo with a glaring lamination to make me change it now.  ;D
« Reply #73 on: April 28, 2012, 09:19:39 AM »
   Chris ,
Thanks Gregory. That's high praise indeed from a modeller of your calibre. I'm finding this project is a real challenge so hearing that the woodwork is okay makes me feel a bit better about it.
In hindsight, I should've used regular wire for the bracing because lead wire is too soft and flexible for the rolling technique to work.
« Reply #74 on: April 28, 2012, 09:24:14 AM »
Chris,
Lovely work on the interior and struts! Beautiful wood grain effect!
