Author Topic: Roden's 1/32 S.E.5a (Wollseley Viper) - Grinnell-Milne's 'Schweinhund'  (Read 61220 times)
Re: Roden's 1/32 S.E.5a (Wollseley Viper) - Grinnell-Milne's 'Schweinhund'
« Reply #45 on: April 24, 2012, 08:42:31 AM »
Looking good Chris.
Paddy
Thanks Paddy. I appreciate you dropping by to have a look.
« Reply #46 on: April 24, 2012, 08:45:20 AM »
Excellent work on the ignition leads Chris, the lead wire was a good idea. Looking forward to seeing more progress on this beauty.
« Reply #47 on: April 24, 2012, 08:52:04 AM »
Chris,
   Your Viper comes off very well; I'm particularly impressed with your ignition wiring harness. I havn't built this kit, stayed with the WNW "Hisso" version and only finished the portion of the engine visible with the cowlings on. Nicely done.
Looking forward to more photos as she's completed.
Thanks for taking the time to comment Lance. I seem to struggle with wiring harnesses made from copper wire but this lead wire makes the task a lot easier for me.
« Reply #48 on: April 24, 2012, 09:05:54 AM »
Just move the baseball bat to another room if you happen to have one in close proximity to the work area ..... getting up and having to go get it gives you time to realize what your about to do!
I've never been a patient modeller (or anything else for that matter) but since starting to build these WWI birds, I've found that I've changed. I'm now able to walk away from the model when I run into difficulties, sometimes after just a few minutes of working on it. Some days, when things don't go well, I spend more time setting everything up on the kitchen table and taking it down, than I do modelling. Two years ago, before I retired, I'd have used the bat!
« Reply #49 on: April 24, 2012, 09:12:35 AM »
Thanks for the images of your WnW engine on your site. Before I saw those, I was lost. My plug leads are getting better with each build I tackle, although I'll be the first to admit that I don't enjoy doing them at all. The lead wire did make it easier for me but I'll never approach the craftsmanship of your wiring jobs!
« Reply #50 on: April 24, 2012, 10:15:49 PM »
You certainly have overcome some major hurdles with paint pulling etc.  It is coming along quite nicely due to your perseverence and skill.  Like Lance, I only spent enough time on the visible portions of the engine, vice detailing it, as I like the buttoned up look of an in service a/c.  Your work is noteworthy and will certainly add some interest to the forward section of the a/c.  Patience is a virtue learned and practiced every day.  I do the same, get up and get away for awhile, and then come back to it.
« Reply #51 on: April 25, 2012, 03:49:49 AM »
Thanks Mark. As odd as it sounds, everytime I experienced the paint pulling was when I was using thin strips of Tamiya tape. The larger pieces of masking all peeled off faultlessly. I don't know why that would be, but I'll be apprehensive every time I use narrow strips from this point forward. Bud posted a link for a source of masking strips he uses and I think I'll give them a try.
« Reply #52 on: April 25, 2012, 03:01:52 PM »
Great looking motor. Now the only fear is the dreaded Roden engine to fuselage fit. Why did they name their company after a giant Japanese rubber flying chicken? Toko was so bad?
Offline Pete Nottingham
« Reply #53 on: April 25, 2012, 05:33:01 PM »
That 'Viper' is looking real good Chris.
Pete.
Offline Whiteknuckles
« Reply #54 on: April 25, 2012, 06:07:45 PM »
Roden wasn't that bad but, personally I love Gamera the mutant turtle, especially his flying technique ;)
The Viper looks great Chris!
Eternal Apprentice
« Reply #55 on: April 25, 2012, 10:01:15 PM »
  Chris,
Great job on the Viper my friend.
Offline Frank Berger
« Reply #56 on: April 25, 2012, 11:42:03 PM »
Chris,
Looking good so far! Gives me some confidence to tackle my next project, a Roden D.III.
« Reply #57 on: April 26, 2012, 02:24:26 AM »
Thanks Steve. Yeh, I'm not looking forward to the engine fit issues!
« Reply #58 on: April 26, 2012, 02:28:52 AM »
Thanks Andrew. Were these things in Godzilla movies, or am I showing my age?  :P
« Reply #59 on: April 26, 2012, 02:32:18 AM »
Chris,
Roden kits can be trying at times but from my limited experience, the final product always seems to look pretty good. I find their instructions to be somewhat vague in part placement at times so I tend to build these kits very slowly . . . and still make mistakes.  :P
