Author Topic: SPAD S.VII Special Hobby//1:48// Italian Aces - part 4  (Read 9838 times)
Offline KrzysiekK
« on: February 25, 2016, 12:12:23 AM »
Hello,
After NI-11/17 and Ansaldo Balilla it's time for SPAD 7:)
In order to improve the outcome I have decide to purchase Part PE dedicated to that item. Unfortunately I made the mistake and had not dug into the net to find some info regarding Part PE application with SH SPAD 7 in 1:48. Most significant parts are overestimated in size, which made all assembly little harder. In 32 it looks better!
I have started with frame which was too big or thick for application. So got rid of some layers of plastic from fuselage halves and cut little bit the frame
it worked out
regards
K
« Last Edit: February 25, 2016, 04:57:30 PM by KrzysiekK »
Re: SPAD S.VII Special Hobby//1:48// Italian Aces - part 3
« Reply #1 on: February 25, 2016, 12:26:18 AM »
Terrific start!! I admire anyone who can bend and install those Part PE frames without totally mutilating them and the bracing wires  8)
« Reply #2 on: February 25, 2016, 12:52:55 AM »
Good beginning.
Offline iwik
« Reply #3 on: February 25, 2016, 12:57:47 AM »
Hi there!
For info the cockpit opening shouldn't be symetric.
IWik
PS Good luck with the Part pe parts.... :o
« Reply #4 on: February 25, 2016, 01:27:40 AM »
I absolutely agree with RAGIIIs opinion. You are managing those PART PE parts perfectly. I'll follow this post closely, I always wanted to see how this Special Hobby SPAD will turn out using the PART PE. :)
« Reply #5 on: February 25, 2016, 01:31:34 AM »
Excellent start, K!  I'm looking forward to following this build since I'm using the Part PE set on my Sopwith Strutter.
Offline dtomko
« Reply #6 on: February 25, 2016, 01:34:04 AM »
Very impressive.  I'm following closely as I think this will be my next build.
Drew
« Reply #7 on: February 25, 2016, 03:29:24 AM »
 K,
Outstanding first progress my old friend. Being such a SPAD fan you can count on me following very closely. I'm also glad you've included the Part PE set as well. Keep up the high excellence!
« Reply #8 on: February 25, 2016, 04:26:41 AM »
This is going to be a great build to follow.  I have the 1/32 Roden version
of the SPAD and want to try and use the Part PE set.  Yours will be a
terrific example to follow, K.  Lead on, my friend!
Offline TobyCoulson
« Reply #9 on: February 25, 2016, 08:01:17 AM »
Now that is very impressive
Offline KrzysiekK
« Reply #10 on: February 25, 2016, 05:04:42 PM »
Thanks All of You!
BTW. I am following PrzemoL's SPAD 7 in 32 thread from thearerodrome, so it might be helpful for everybody
Hi there!
Could you pls explain what should I be afraid of in the cockpit area. Thanks in advance!
regards
K
Offline xmald
Re: SPAD S.VII Special Hobby//1:48// Italian Aces - part 4
« Reply #11 on: February 25, 2016, 05:34:39 PM »
Hi Krzysiek! SPAD VII you say, maybe after finishing my Deperdussin I will start mine. What is better motivation than watching your thread here! Should you need decals for the Polish markings I can send them to you;)
The frame looks great, it's always  a shame to hide inside the cockpit isn't it?
What painting scheme do you intend to use?
Best regards
Filip
« Reply #12 on: February 25, 2016, 05:42:41 PM »
Extremely nice work with the PE, well done.
Offline KrzysiekK
« Reply #13 on: February 26, 2016, 05:12:54 AM »
Thanks Filip! Indeed almost nothing will be visible after assembly. I am going to perform Italian marking of Fulco Ruffo di Calabria and do have the question to you guys.
Does anybody know if or what kind of radiator shutters/blind was applied on Italian SPAD's?
Thanks in advance!
K
Offline KrzysiekK
« Reply #14 on: March 01, 2016, 06:13:25 PM »
Next I will use some kit resin part to fill the cockpit as create all from PE is too risky and might have been time consuming
I have added all little stuff from PE part which was quite exhaustive and finally figured out that almost nothing will be visible out of this tedious work.
regards
K
