Author Topic: Albatros D-III Oeffag early series 153 / Roden 1/72  (Read 13849 times)
Re: Albatros D-III Oeffag early series 153 / Roden 1/72
« Reply #30 on: March 15, 2016, 12:42:47 PM »
Looking really neat Vincent, the colours are excellent and your decals, apart from the silvering, have been applied well.
Offline jeroen_R90S
« Reply #31 on: March 15, 2016, 05:44:51 PM »
Great looking Albatros! When I use Roden decals, I always apply them over wet acrylic gloss so they stick and don't silver.
It might be too late, but I have a sheet of Pegasus 1/72 A-H serials. If you would like to replace the silvered decals on yours (or paint them over and apply new ones) I'd be happy to send you a few.
Honestly, the silvering does detract from an otherwise beautiful build...!
Jeroen
« Reply #32 on: March 15, 2016, 10:31:06 PM »
Looking good! I like the subtle undersurface weathering!!
« Reply #33 on: March 16, 2016, 06:17:13 AM »
Very good work Vincent.
Offline vincentm
« Reply #34 on: March 29, 2016, 10:19:48 AM »
Thanks.
Thank you for your offer Jeroen, but removing the decals now they're covered with a coat of varnish, would damage the paint. I'll have to go on with scratching the remaining shining areas...
I've been able to take the build over, installing the semi-buried U hooks for the rigging:
But before I can complete it, I'll have to finish a spanish republican I-16 I had started just before. Fortunately it's in the final stages, I've started weathering it.
« Reply #35 on: March 29, 2016, 09:37:45 PM »
Vincent, how you can even see those bits of wire, I don't know,
but you are doing an amazing job as always, my friend!
Offline 2996 Victor
  • Over the Front
« Reply #36 on: October 18, 2021, 05:57:06 PM »
Hi Vincent,
I realise this is a bit of thread resurrection, but did you ever complete your Albatros D.III? It was looking absolutely stunning, so I do hope so!
I'd also like to know what sort of printer you use for your instrument decals. As a very recent returnee to the world of Great War aviation and in particular Austro-Hungarian scouts, the lack of good instruments is a bit vexing!
Many thanks and kind regards,
Online Brad Cancian
    • Brad's Models
« Reply #37 on: October 22, 2021, 03:55:25 PM »
Great work! I built this same kit a little while back -
I found the top wing to be a bit troublesome to mount; the interplane struts are too long and push the bottom wings down; as you can see with my model, the dihedral is way off as a result. Recommend doing some test fits and trimming of the struts to make sure you don't run into the same problem that I did.
Great stuff!
BC
Offline 2996 Victor
  • Over the Front
« Reply #38 on: October 22, 2021, 05:06:19 PM »
Great stuff!
BC
Beautiful work, Brad! The wood finish to the fuselage is so convincing, subtle shade changes and just a hint of the wood grain. Superb! How did you achieve the sworl fabric?
Kind regards,
Online Brad Cancian
    • Brad's Models
« Reply #39 on: October 22, 2021, 06:38:04 PM »
Thanks Mark! Rather than hijacking this great thread, i'll point you to my build log - over here:
https://forum.ww1aircraftmodels.com/index.php?topic=3936.0
That should hopefully answer your questions  :)
BC
Offline 2996 Victor
  • Over the Front
« Reply #40 on: October 22, 2021, 06:49:01 PM »
BC
Thanks, Brad, that's really appreciated!
Offline hadzi
« Reply #41 on: October 31, 2021, 02:36:35 AM »
Great little Öffag!
Offline Dric
« Reply #42 on: November 04, 2021, 04:40:51 AM »
Splendid little birds !
