Author Topic: Sopwith 7F.1 Snipe (1/32, Wingnut Wings)  (Read 13552 times)
Re: Sopwith 7F.1 Snipe (1/32, Wingnut Wings)
« Reply #15 on: December 30, 2015, 10:24:34 PM »
Thank you for your overwhelmingly kind comments. Yet, I wish to stress, that every possible praise should go to Lukasz. I only played a role of an assembler.
I have mixed feelings about it not fitting into the cowl. On one hand, it would be nice to be able to have a complete airplane with the cowl in place, but on the other hand, it would be a shame to hide that beautiful engine.. ???
George
My thoughts, exactly, George. A hard choice had to be made here. Snipe has such a charming nose (beak ;)), but my model will not show it.  :(
If the cowling has to be thinned that much would you consider using it as  a master and plunge a new one from heated plastic sheet?
That would be an option, but heat-forming is well beyond my skills and possibilities.
Given the engine is more or less 90% hidden by the cowling have you considered the Kit engine installed with the Taurus Bentley displayed beside the model?
I am not for dioramas, even at the slightest, Lance. What I do at the most is some basic base, and this only for floatplanes which must have a landing gear not to  look weird. But thanks for your suggestion.  ;)
And after all, there would be enough of WNW Bentley visible to notice that it is clunky when compared to Taurus one.
When buying Lukasz's engine I was sure I wanted to install it in this model. The fact, that the cowling is too large, made my decision easier to expose it completely. Otherwise, I would be torn in two, between the great engine and nice Snipe beak.
So, the model will have no cowling and no propeller, they may just be somewhere at the side, propped against the undercarriage, or so. Will think of it, yet.
Offline Pgtaylorart
« Reply #16 on: December 31, 2015, 03:31:01 AM »
This is really making me think about what I should do with my Snipe. I actually bought the Taurus Bentley first, and bought the Snipe as a place to display it! ;D
I'll be watching closely to see what you come up with.
George
« Reply #17 on: January 09, 2016, 09:01:42 AM »
After a few busy modelling sessions I finally managed to complete the cockpit. Everything fits very well, WNW have done again a great job. But do not be deceived with its apparent simplicity. The interior is very crowded, access to the inside becomes more and more complicated with every bit added. And I have made it myself even more difficult postponing the internal bracing for after the assembly. This was a severe mistake and the part of WW1 aircraft modelling which I find my favourite became almost nightmarish. I had again to use the watchmaker's magnfying glass to pass the lines through the prepared eyelets and manouvering the tweezers was very tricky. Finally I managed to complete it but those mere 18 cables were probably most difficult ones I have ever had and will long be remembered. So my advice is to do this bracing BEFORE the assembly.
From my side I have only replaced the pulsator moulded into the instrument panel with Lukasz product (amazingly fantastic!!!) and a piece of tin wire bent to shape and painted copper, also the gun trigger cables going along the stick, plus all the control lines from the stick and the rudder-bar - these will go unbroken all the way through the fuselage interior to the control surfaces - not functional though.
Also the fuselage interior in visible parts got the colours and some bracing. It is now basically ready to accept the cockpit and close it forever.
« Reply #18 on: January 09, 2016, 09:22:14 AM »
Exceptional work on the cockpit Przemol, it is a very crowded little space but you have managed to make it look realistic, the colours you used are excellent.
« Reply #19 on: January 09, 2016, 09:23:50 AM »
Truly magnificent interior, my old friend.  I can't see how you could possibly have rigged the frame work while fully assembled, but you did.  A testament to your amazing skills.
« Reply #20 on: January 09, 2016, 09:38:14 AM »
That cockpit module is just beautiful!
« Reply #21 on: January 09, 2016, 10:33:36 AM »
 Prze,
Outstanding engine and interior my old friend. Very impressive wood work on her airframe. Looking forward to following along.
« Reply #22 on: January 09, 2016, 11:00:56 AM »
I hope you still have some hair left after doing the rigging  ;) Well done so far Prze  8)
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #23 on: January 09, 2016, 11:51:23 AM »
Hello again!!!
Fantastic work on interior!!! I can now see even clearer the difference between "old" and "new" WNW after you pouted it out... Might put my Snipe higher on my "what's next" list  ;)
Cheerio
Lukas
Lukas
Offline ade
  • "..ambition? To be Elvis Costello"
« Reply #24 on: January 09, 2016, 05:44:58 PM »
Wonderful work!
True genius  :D
« Reply #25 on: January 10, 2016, 12:21:58 AM »
You have turned a very good kit interior into a Brilliant kit interior! Painting, assembly, and rigging are just OUTSTANDING!
Online lcarroll
« Reply #26 on: January 10, 2016, 12:27:05 AM »
Just a fantastic job on the cockpit, Prze, a real tribute to your skills as always! The rigging comes off beautifully, well worth your considerable efforts IMHO.
« Reply #27 on: January 10, 2016, 12:33:54 AM »
Beautiful and inspirational work! Well done! The extra details are quite amazing.... Marc
« Reply #28 on: January 10, 2016, 03:03:27 AM »
Thank you, everybody for your kind words.
Some more progress:
Fuselage ready to be closed (with the tail skid added)
And just after closing
Offline moustique
« Reply #29 on: January 10, 2016, 03:46:25 AM »
your engine is absolutly  fantastic
the cockpit is brilliant
it will be a masterpiece
bravo
