Author Topic: RAF BE.2F (original) A1325, Omaka and Hood, NZ  (Read 2597 times)
« on: December 03, 2015, 05:31:03 AM »
Kinda surprised this lovely lady of almost-99 hasn't a thread of her own, unless I've missed it.
A1325 is an original BE.2f, built in 1917 and currently the oldest original Geoffrey de Havilland-designed aircraft in airworthy condition worldwide.
Stuart Tantrum restored her in New Zealand, first at Levin in the North Island and then at Omaka, near Blenheim, in the South Island. Sometime before completion the project was sold to Peter Jackson or one of his companies and restoration continued, culminating in a successful first flight in 2009.
Some info about the project from TVAL's website (copy-and-pasted, including grammar and spelling errors):
Quote
This project had previously been worked on by several different organisations both in the UK and in New Zealand. Initially this project was thought to be a BE2e and prior to arriving in our workshop quite a lot of work had been carried out under this misconception. From our library of drawings and photographs we deduced that it was in fact a BE2f , which is outwardly very similar to a BE2e but with the major difference that the fuselage is from a BE2c. The main indicators of this, which can be backed up with drawings are- the rear decking of the fuselage is ply covered; this was replaced with wire bracing in the BE2d and BE2e and even in some later BE2c’s, the main vertical strut in the fuselage just in front of the pilots seat is made from Ash- this was a steel tube in the BE2e. The lower main longitudinal members are shaped differently in the two models- the original ones that came with the project are of the BE2c variety. And, finally, there are a myriad of minor differences in the bracketry, that, while individually may not be to persuasive, when they are grouped together confirm that this was indeed definitely a BE2c fuselage.
Armed with this information we set about undoing some of the painstaking and delicate work that the earlier organisations had carried out in the belief that they were working on a BE2e fuselage. It was believed to be part of a batch of BE.2's delivered to Norway by the RFC in 1917. It was eventually donated to the Mosquito Museum in the UK (the BE.2 being an early DeHavilland design), and after several years it found it's way into private ownership - and put up for sale in WW1 Aero magazine. It was acquired by the NZ based 1914-18 Aviation Heritage Trust over 10 years ago. The fuselage was in great condition, with a lot of original timber in airworthy standard. A set of reproduction wings had been made for it in the UK (not entirely accurately as it turned out), and it arrived with an original RAF 1a engine in very poor condition.
The engine problem slowed the project down for a while, but during that time full advantage has been taken of the uncovered original airframe. The Vintage Aviator has made several reproductions, with appropriate modifications to reproduce a range of different BE.2 models. With reproduction RAF 1a engines now well underway, work began in earnest to return A1325 to the air.
We replaced the lower longitudinal members with the original ones that had previously been removed. And then we removed the BE2e fuel tanks, front seat frames, cowl and carlin arrangement, front wing spar carry-through tube and engine bearer braces. We then fitted new engine bearer braces, carry-through tube (with fuel tank mounting brackets attached), carlins and cowl and a BE2c main tank- all of which have been made to the original drawings. The passenger’s seat is now bolted directly onto the top of the main fuel tank.  Most of the work on this plane has been carried out in conjunction with the reproduction Be2f and the early type and late type BE2c’s that we are building. Throughout these projects it has been easy to see where the confusion lay when these planes were being manufactured originally and why they re-designated the BE2c and BE2d fuselage fitted with BE2e wings as the BE2f and BE2g respectively.
These are the only two photos of ZK-BFR I took on Saturday. I don't believe she left the hangar at all. A friend was fortunate enough to be offered a ride in her a few months back and had a great time.
Breaks down for easy transport!  :P  This and the following shots were taken at Classic Fighters 2009 at Omaka, the aircraft's airshow debut. From memory she was flown by Stuart Tantrum, or possibly Gene DeMarco.
Re: RAF BE.2F (original) A1325, Omaka and Hood, NZ
« Reply #1 on: December 03, 2015, 05:38:41 AM »
Thanks Zac for the wonderful photos. It is truly amazing that an aircraft approaching being 100 years old is still looking so good and flying, the restoration was beautifully done resulting in such a magical looking aircraft, well done to everyone and may she keep flying for many more years.
« Reply #2 on: December 04, 2015, 05:13:26 AM »
Thanks Des, I'm happy to share them. I didn't realise I'd taken so many photos. I also found one more:
« Reply #3 on: December 04, 2015, 05:27:48 AM »
Yes, thanks Zac.
Best wishes from another of the BE.2 officianados
