Author Topic: JB spark plugs  (Read 7685 times)
Re: JB spark plugs
« Reply #15 on: February 13, 2016, 12:19:21 AM »
I think that's up to the modeler
now, about the lead connection .... short of attempting to drill a hole, is just "butt joint" gluing the best way around? seems like a mechanical joint would offer more strength in the long run.
I made lead ends from .4mm tubing, squashed and drilled:
Re: JB spark plugs
« Reply #16 on: February 13, 2016, 02:12:24 PM »
Like Bo, I make my connectors from flattened 0.4mm brass tube with a 0.3mm hole drilled to slip over the spark plug, with a drop of CA it makes for a very positive and strong connection.
Offline southpier
Re: JB spark plugs
« Reply #17 on: February 20, 2016, 08:33:06 PM »
yeow; that's some tiny stuff. what wire is that with the spiral wrap? sorry; the questions just keep coming.
Offline petrov27
Re: JB spark plugs
« Reply #18 on: February 21, 2016, 12:51:11 AM »
awesome tips here - the flattened tube ends on the plug wire I gotta try....
-Patrick
Re: JB spark plugs
« Reply #19 on: February 21, 2016, 05:29:53 AM »
i think the wire I used for the spiral wrap was something like .05mm... can't remember off hand (and not home to measure it) -- anyway very small ;)
Re: JB spark plugs
« Reply #20 on: February 21, 2016, 07:39:24 AM »
The spiral wrapped wire I use is 0.23mm, it fits very nicely into the end of the 0.4mm brass tube.
I get my wire from ear plugs, the small plugs that fit inside your ear for listening to music etc, there are three wires inside the small white plastic outer tube, I buy the ear plugs from $2 shops so you can strip a lot of ignition leads for very little expense.
« Last Edit: February 21, 2016, 07:46:16 AM by Des »
Offline s.e.charles
Re: JB spark plugs
« Reply #21 on: December 23, 2021, 04:46:13 PM »
thanks for the lead (pun intended).
i really need to visit more often!
