Author Topic: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b  (Read 44722 times)
Offline FarEast
Re: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b
« Reply #75 on: October 28, 2015, 07:26:03 AM »
So last night I cut and laid the last of the masks on the fuselage. I will study the reference photos a little more to make sure I didn't miss anything but she's pretty much ready for paint.
For those interested there are over 600 scales covering the fuselage.
« Reply #76 on: October 28, 2015, 11:51:31 AM »
  James,
Over 600 scales! And such beautiful work too. This thread just keeps getting better and better with each update my old friend. Keep up the high level of Excellence.
« Last Edit: October 30, 2015, 11:27:04 PM by GAJouette »
« Reply #77 on: October 28, 2015, 10:42:02 PM »
Impressive doesn't begin to cover your masking job! Looking forward to seeing the results.
Offline Pgtaylorart
« Reply #78 on: October 29, 2015, 02:26:47 AM »
Over 600 scales! I'll stop complaining about masking off rib tapes now... ::)
I can't wait to see the results or your painting and masking.
George
« Reply #79 on: October 29, 2015, 02:45:41 AM »
    This is truly a fine example of attention to detail, just spectacular........ :o I'm waiting for the completed finish, this is going to be "one of a kind"!
Offline FarEast
« Reply #80 on: October 30, 2015, 11:01:45 AM »
Well after consulting again with the fantastic guys over at Wingnut Wings I decided to add another layer of detail.
This time it is a clear dope linen layer as this was how they were finished after the two halves were joined. The reason for this is that it will also play a huge effect on the shading and colouring of the 'Light Blue' rag rolled finished.
So again it was time to preshade the fuselage and apply several coats of thin coats of Tamiya 'Deck Tan'
Now my hope is that the dark blue pre-shading and top coats, followed by the CDL pre-shading and top coats blends perfectly along the seam lines and other detailing on the fuselage.
So time to start carefully peeling off the masks to see what we have!
Overall I'm really pleased with the finish, I feel the pre-shading blends perfectly between the two colours and that the method used has been effect for what I wanted to create. Now I need to look at how to achieve the effects of rag rolling over the top of these with the 'light blue' found on the Roland C.II aircraft.
« Reply #81 on: October 30, 2015, 11:27:44 AM »
it's brilliant -- and probably far nicer than the original.
« Reply #82 on: October 30, 2015, 11:28:04 AM »
You have done a superb job with the scales James, this model is looking excellent.
Offline FarEast
« Reply #83 on: October 30, 2015, 11:33:37 AM »
Thanks guys, I now have to apply the 'light blue' coat over the top - the original aircraft were 'rag rolled' a rage dipped in paint and then rolled over the fuselage. I have no idea of how to apply this though.
One idea was to actually rage roll it using sponge or tissue (cotton) paper. However, I saw Rahmi's fantastic FE.2 and saw that he had achieved a mottled effect on the nacelle and that might be the way to go?
Only I have no idea how it was done! :D
« Reply #84 on: October 30, 2015, 11:56:44 AM »
my suggestion -- apply a few coats of X-22, let it cure a few days, and then do the overpainting with oils, either applied with a rag analog or sprayed. Don't like it? wipe it off and start over.
Offline Pgtaylorart
« Reply #85 on: October 30, 2015, 01:08:56 PM »
Maybe rolling a Q-tip, or cotton bud (as they are called outside the US) dipped in paint. Possibly blot the paint off a bit as you would in dry brushing.
George
« Reply #86 on: October 30, 2015, 11:23:04 PM »
Exellent painting James.
Michael Scarborough
« Reply #87 on: October 30, 2015, 11:50:09 PM »
Looking really wonderful, James....makes me want to take the Missus out for sushi tonight.
You might consider miniature rag rolling with blue paper towel. Not sure where you are in the world but they're referred to as shop towels here in the State and made by Scott. Considerably heavier than kitchen paper towels and do not fall apart when moistened. I go through them by the case in my studio.
Read up on "rag rolling" a faux-finish on walls and I think you will find you can use the same method, but in miniature. If you're using acrylics, as I'm sure you know, add retarder to extend the open time on the paint.
If I were doing it, I believe I'd use oils because they will allow you a lot more flexibility while working with the paint. Add a bit of Oil Paint Medium which will increase the viscosity of the paint without making it runny. There are many varieties but I use W&N Artist's Painting Medium. One note: this will tend to make the oils glossy, but, if you'll be using any sort of pin washes over the oils, this will just help that process. I'd also add a drop of Japan drier to speed up the drying time. As long as you've laid down a good barrier coat of acrylic, you can play with the oils and wipe them off if you don't like the effect you're trying to achieve.
As with everyone else, I'm sure looking forward to following the rest of this build.
Cheers from NYC,
Michael
Offline FarEast
« Reply #88 on: October 31, 2015, 11:26:48 AM »
Thanks for all the advice everybody I've learned so much from many of you here and it's very much appreciated.
So this morning I decided on a course of action what I did was I laid a coat of the light blue to blend all the colours as I did on the test piece and already its looking like its finished but with a perfect coating. This is now in the processof receiving several coats of clear. Once cured I will use oils to create the rag roll effect with sponge.
As you've all agreed this way I can correct the effect if it all goes pear shaped.
Offline FarEast
« Reply #89 on: October 31, 2015, 10:49:42 PM »
So that's done - This is how she's looking with several very thin coats of the 'light blue', this was done unevenly as I want to start breaking up the uniformed look - I'm trying to replicate a hand painted effect after all. This was then followed up with a few layers of clear coat.
We have a national holiday on Tuesday so I will leave it till then and then give the oils a spin! Now its just a case of colour matching, I found several 'blues' but nothing that was a perfect match so I will have to experiment.
