Author Topic: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b  (Read 44532 times)
Offline LukasTheLight
  • Addicted to Wingnuts...
Re: Wingnut Wings 1:32 Roland C.IIa (Early) Feldflieger-Abteilung (A)292b
« Reply #15 on: October 06, 2015, 12:43:10 PM »
Hi James!!!
Once again - great work!!! And great pictures and great tutorial(s)!! ;) Thanks for those, I will sure be using them... ;) Looking forward to see more progress on this beauty!!!!
Cheerio
Lukas
Lukas, thank you for your kind words, comments are always very much appreciated and help keep me motivated to push things..... when I grow up I want to be like you and Bo Monroe! :D
Wow, you made me smile, you want to be like me? :) Im more about the other way around... seeing your builds and your progress is very encouraging!!! ;) And I guess Bo is a huge inspiration for many of us here ;)
Cheerio
Lukas
Lukas
« Reply #16 on: October 06, 2015, 12:57:16 PM »
Truly inspirational work, James!  Can't wait for the next update!
« Reply #17 on: October 06, 2015, 06:25:32 PM »
Fine modelling. I am looking forward for more.
« Reply #18 on: October 07, 2015, 08:56:46 AM »
I love your work James.
« Reply #19 on: October 08, 2015, 08:13:33 AM »
Magnificent work on the interior! Your photographs are also outstanding!
« Reply #20 on: October 08, 2015, 08:34:42 AM »
You are doing a superb job with the interior James, your attention to detail is exceptional.
« Reply #21 on: October 08, 2015, 08:38:54 AM »
Lookin' good!
Quote
Right time to look for some 1:32 scale German Ammo belts!
Taurus and / or Gaspatch for those ... ;)
Offline FarEast
« Reply #22 on: October 08, 2015, 10:36:42 AM »
Just a tiny update.
Last night I removed the ammo from the magazine and then using a base coat of Vallejo black primer I coated the magazine with Uschi van der Rosten polishing powder.
I sprinkled the powder on while the primer was still tacky and then using a large flat brush brushed off the access powder in one direction and continued to do so until I achieved the desired effect of brushed aluminium.
« Last Edit: October 08, 2015, 10:41:29 AM by FarEast »
Offline ermeio
« Reply #23 on: October 08, 2015, 02:44:17 PM »
Simply fantastic!
Thanks for those pictures
« Reply #24 on: October 08, 2015, 03:17:45 PM »
Nice!!!
« Reply #25 on: October 08, 2015, 11:00:39 PM »
Nice!!!
I know no one will believe this but the first word that came to my mind was NICE!   ;D
« Reply #26 on: October 08, 2015, 11:36:21 PM »
James,
   I was away when you started this Log and just saw it now for the first time. Magnificent work! Your detail is wonderful and the finishing simply outstanding, I'll be following your progress closely, a lot of great learning points and hints here. :o
Offline FarEast
« Reply #27 on: October 11, 2015, 09:25:53 AM »
So another Saturday and another good session at the work bench.
First of all some metal parts on the firewall. I used the Uschi van der Rosten Chrome Polishing powders for this.
  • Flat black base coat
  • Apply powder while paint is still wet - I pour it all over the part to saturate it
  • Immediately start brushing the powder away. I brush in one direction only to achieve a brushed aluminum or worn look.[/i]
Dump powder on and brush excessive away.
Brush in one direction for 'brushed aluminum look' or polish with powder saturated cloth for high gloss.
Job done
Next up was the observers chair, now as this is a flip up chair and constantly being moved, sat on, knelled on and generally abused I thought I would make the scuffing of the leather a little more prominent - This is before the washes to were applied to blend the colours in.
After the washes
So then it was time to put into place the rest of the ribs and engine mounts.
I also started on adding a little extra detail to the parts that would just be free floating otherwise.
Making sure it all aligns.
Offline FarEast
« Reply #28 on: October 11, 2015, 09:59:41 AM »
So with that done and little else to do internally until it's time to close her up I moved on to the Daimler-Mercedes D.III engine.
Now I'm awaiting some parts from Łukasz Laskowski at Taurus models, the original plan was to build this 'Out of the Box' however that all went out the window when I saw the difference in quality of the stock magneto vs  Łukasz' Taurus part. So I'm waiting for the following;
Complete timing gear with valves springs and lifters for Mercedes DIII
Priming cups for Mercedes DIII/DIIIa
Intake maniflod nuts for inline WWI engines
But I was still able to make a start on it and prepare it for those parts.
The engine block was done the same way as other aluminum parts, flat black base with Uschi van der Rosten powder applied immediately and brushed. The water pipe was done using Vallejo Copper and then dry brushed with Uschi Chrome powder to highlight the edges.
Next up was the Intake pipes - this is a very easy modification, I use a domestic masking take that is very thin and pliable to wrap them and secure in place with a few dots of CA glue. This will receive a coat of Mr Surface primer before painting to lock everything in.
« Reply #29 on: October 11, 2015, 10:15:06 AM »
Superb work, James!  I'll have to give those powders a try.
