Author Topic: 1/32 Special Hobby Nie11/16 Laurence Rumsey, Lafayette  (Read 3935 times)
Offline KiwiResin
« on: September 23, 2015, 01:38:40 PM »
While I wait to build up the courage to rig the Spad 13, I decided to break this out of the stash:
Special Hobby Nieuport 16 which I will build as Rumseys repaired machine:
The Special Hobby kit is quite nice, lots of resin, good quality ( but not WnW) plastic, and a PE fret
I will use my own recent released 1/32 Kiwi Decals Lafayette sheet for this aircraft ( shameless plug!)
Ive made a start on the engine first, all resin and a complicated build, complete with separate spark plugs and pushrods.
I managed to put the cylinders on around the wrong way as I DIDNT read the instructions, and the last rotary engine I worked on was a Gnome, of course this is a Le Rhone and is quite different, what a fool I am.
Initially I gave the whole engine a coat of Tamiya spray silver, then a wash of thinned humbrol gun metal.
After the wash I sponged some dull silver on the crankcase
This gave me a nice cast metal impression
Followed with a wash of copper over the induction pipes, and replacing the resin pushrods with rolled solder
Apart from the ignition harness, the engine is now complete
« Last Edit: September 23, 2015, 01:46:55 PM by KiwiResin »
Re: 1/32 Special Hobby Nie11/16 Laurence Rumsey, Lafayette
« Reply #1 on: September 23, 2015, 02:31:38 PM »
Great to see this Special Hobby kit being built, you have made a terrific start with the engine, the colour is excellent.
« Reply #2 on: September 23, 2015, 10:13:56 PM »
Your engine looks great! I have pulled this box out of the pile many times. Perhaps your build will be the inspiration I need to actually build the kit !
Offline Kreston
« Reply #3 on: September 23, 2015, 11:42:19 PM »
Have always been curious about this kit.  I look forward to watching your build.
Offline jamieg
« Reply #4 on: September 23, 2015, 11:46:53 PM »
I saw this on Hyperscale as well. It will be interesting to see a build of one of these.
Jamie
« Reply #5 on: September 24, 2015, 05:18:01 AM »
Dittos, the engine looks great-- makes it worth the price of the kit !
« Reply #6 on: September 24, 2015, 08:48:03 AM »
Very good engine.
Offline KiwiResin
« Reply #7 on: January 17, 2016, 12:07:25 PM »
More progress at last on the Bebe
Ive managed to complete the interior. But for some reason the internal rigging would lose tension overnight. In an attempt to tighten it i hovered a hot needle near it, which melted the bracing. Of course its too late to remove it now.
Time to stitch the fuselage together :-)
« Reply #8 on: January 17, 2016, 12:30:19 PM »
Great work on the cockpit and fuselage interior.
« Reply #9 on: January 17, 2016, 04:16:46 PM »
 Kiwi,
Beautiful work on her engine my friend. Equally impressive work on the interior as well. I do wonder about the use of blue for the steel pieces of the interior though. I was under the impression that these should be black or possibly natural metal (silver) for Nieuport aircraft and that blue would be proper for a SPAD. That being said the blue does certainly look great. If you feel it's necessary to replace the internal rigging I would suggest using Easy Line or similar product. Looking forward to the next excellent update.
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #10 on: January 17, 2016, 04:28:47 PM »
Fantastic!!!!
It makes me want to start mine and sign it for French GB ;) Watching closely ;) great work on engine and cockpit!
Cheerio
Lukas
Lukas
Offline KiwiResin
« Reply #11 on: January 17, 2016, 06:49:43 PM »
Kiwi,
here is an original at the Musee de l'Aire.
Of course this could be incorrect also...
Offline Suffolk Lad
« Reply #12 on: January 17, 2016, 07:26:11 PM »
Very nice work Kiwi - you have given me the metaphorical kick in the butt I need to continue with mine in the GB
You've made a very nice start on the internals and the engine - looking forwards to further updates. Thanks for the inspiration  ;)
Regards - Tug
