Author Topic: WNW Salmson 2A2/Aviattic figures: WNW Pfalz DIIIa Jasta 4  (Read 167679 times)
Re: WNW Salmson 2A2/Aviattic figures: WNW Pfalz DIIIa Jasta 4
« Reply #180 on: December 08, 2015, 09:19:29 AM »
As great as the Pfalz looks, I'm looking forward to a little update on the Salmson...  :P :-)
Thanks for the comment! As for the Salmson I am on my 3rd day of my 4 day rotation at work tonight so I should get some bench time Wed throughSaturday  8)
« Reply #181 on: December 13, 2015, 01:49:16 AM »
I have progressed on the painting of the Salmson. The only colors left to apply are the fabric brown color and black, for the uppers, and the beige/ecru on the unders. This is a teaser photo as I will take better shots once all of the initial paint is laid down. After that the post shading will be done.
WNWsalmson 002 by Richard Geisler, on Flickr
WNWsalmson 005 by Richard Geisler, on Flickr
« Last Edit: August 15, 2017, 08:49:32 AM by RAGIII »
« Reply #182 on: December 13, 2015, 02:01:55 AM »
Gorgeous paint work, Rick!  Did you paint over an aluminum base or did you mix aluminum in with the colors?  I can see a very subtle metallic sheen in there.  Lovely work.
Offline IFF1418
« Reply #183 on: December 13, 2015, 02:32:43 AM »
Magnificent work on the tail Rick my friend! A pleasure for the eye. Well done! It's gonna be a beauty!
Kind regards
Patrick
Offline IFF1418
« Reply #184 on: December 13, 2015, 02:37:05 AM »
Hi Rick,
My latest post was about the Pfalz! Your Camo colours on the Salmson look very good, I very much like the soft look of it! Did you choose the WnW proposed mixture? Very nice!
Kind regards
Patrick
« Reply #185 on: December 13, 2015, 02:38:07 AM »
Exellent painting Rick.
« Reply #186 on: December 13, 2015, 08:13:57 AM »
Thanks Bud. I did mix aluminum, actually a mixture of Aluminum and Grey per the WNW directions. After making the aluminum dope I added it to the colors more or less as directed by WNW. The macro photo shows more than the naked eye although it can be seen. It does grey down and lighten the basic colors for some difference between doped fabric and paint on metal. I just lack the black and a little touch up on the uppers now.
Kind regards
Patrick
Thanks for the comments on the Pfalz tail Patrick. Also thank you for commenting on the paint work on the Salmson. I greatly appreciate you following along my Friend!
Thanks Martin, greatly appreciated!
« Reply #187 on: December 15, 2015, 01:04:34 AM »
Here are the promised photos. Still in need of touch up and weathering.
wnwsalmson 003_crop by Richard Geisler, on Flickr
wnwsalmson 006 by Richard Geisler, on Flickr
wnwsalmson 009 by Richard Geisler, on Flickr
« Last Edit: August 15, 2017, 08:53:37 AM by RAGIII »
Offline moustique
« Reply #188 on: December 15, 2015, 01:19:11 AM »
very good paint
Offline IFF1418
« Reply #189 on: December 15, 2015, 01:46:52 AM »
Exquisit painting Rick my friend! Well done, wonderful camo.
Kind regards
Patrick
« Reply #190 on: December 15, 2015, 01:54:09 AM »
Brilliant sheme Rick.
Offline rolanddvi
« Reply #191 on: December 15, 2015, 09:16:12 AM »
Rick,
Beautiful paint job. What did you use to mask the camo pattern?
« Reply #192 on: December 15, 2015, 09:16:49 AM »
very good paint
Thanks, I appreciate you following along!
Kind regards
Patrick
Thanks Patrick!
Thanks Martin. Next up is masking ALL of the ribs on the Pfalz and Salmson :o I plan to use Tamiya smoke and then some oils for weathering. I also found some Testors washes that look interesting  8)
« Reply #193 on: December 15, 2015, 09:18:41 AM »
Rick,
Mike, I use Silly Putty  ::) Just roll it up and place it in position. Never lifts paint and leaves no residue. I have a photo from my Older Nieuport 28 build I will try to locate to illustrate my method. Here is a link to the build:
http://forum.ww1aircraftmodels.com/index.php?topic=2077.60
« Last Edit: December 15, 2015, 09:22:54 AM by RAGIII »
« Reply #194 on: December 15, 2015, 10:37:07 AM »
Beautiful paint work Rick, the colours look perfect.
