Author Topic: Pfalz Dr.I Jasta 73 Ltn. Fritz Anders in 1:48  (Read 42571 times)
Re: Pfalz Dr.I Jasta 73 Ltn. Fritz Anders in 1:48
« Reply #60 on: August 15, 2015, 09:08:23 AM »
Thank you very much, Bud.
« Reply #61 on: August 19, 2015, 05:20:39 AM »
The last few days I have carried out various works.
On the upper surface the ailerons cut out with the corresponding longer version. Miscellaneous plastered and sanded. Used eyelets for tension and holes for the aileron control cables attached, as well as on the hull.
MG`s and tO / transfers painted and finished.
Turnbuckle and eyelets used to the hull, and made flexible turnbuckles.
Engine painted and finished.
Wings and fuselage primed.
« Reply #62 on: August 20, 2015, 09:43:01 AM »
My apologizes for not leaving my comments Martin  , but so far to date you are doing a fabulous job on this kit . Well done ! ;D
« Reply #63 on: August 20, 2015, 09:54:16 AM »
Outstanding update Martin! Looking good!
Michael Scarborough
« Reply #64 on: August 20, 2015, 11:33:00 AM »
Wow! Martin you are a speed demon!! Congratulations on making so much progress!!
Cheers from NYC,
Michael
« Reply #65 on: August 20, 2015, 09:40:03 PM »
Thank you very much for your very nice accolades, Terri, Rick and Michael.
« Reply #66 on: August 21, 2015, 01:58:55 PM »
very good so far martin. you are very good with resin kits.
« Reply #67 on: August 22, 2015, 02:34:12 AM »
Thank you very much, Scott.
« Reply #68 on: August 24, 2015, 03:51:21 AM »
Before I continue paintshop the bottom I have the undercarriage and the side mounted turnbuckles front of the fuselage.
« Reply #69 on: August 26, 2015, 06:41:40 AM »
The model is finished with silver gray.
Before the upper wing is attached, most tension wires, MG`s be fitted with accessories and other parts.
Also, the wheels, other parts and tail sidd are ready painted.
Upcoming wires will follow.
« Reply #70 on: August 26, 2015, 08:41:26 AM »
Looking spectacular Martin!
« Reply #71 on: August 26, 2015, 09:33:35 AM »
Thank you very much, Rick.
« Reply #72 on: August 26, 2015, 10:36:50 AM »
Looking really good Martin, the silver/gray is excellent.
« Reply #73 on: August 27, 2015, 01:07:11 AM »
Thank you Des.
« Reply #74 on: August 29, 2015, 12:17:58 AM »
The bracing is done and painted except the inner struts and for landing gear.
The aileron wires are glue to the fuselage and painted.
The turnbuckles and suspension to the undercarriage is mounted.
