Author Topic: Pfalz Dr.I Jasta 73 Ltn. Fritz Anders in 1:48  (Read 42596 times)
Re: Pfalz Dr.I Jasta 73 Ltn. Fritz Anders in 1:48
« Reply #75 on: August 30, 2015, 03:52:09 AM »
The undercarriage bracing is done with paint.
The engine and front hood attached, and the first MG.
Some paint corrected.
Offline jamieg
« Reply #76 on: August 30, 2015, 08:55:01 AM »
Looking good, Martin. I've got one of these in the stash, but the wings are hopelessly warped.
Jamie
« Reply #77 on: August 30, 2015, 08:59:17 AM »
Thank you, Jamie.
What is with hot water? Take the wings inside and Change the warpe.
« Reply #78 on: August 30, 2015, 12:22:01 PM »
  Martin,
Wow the little gem of a kit is coming along excellently my old friend.
Offline dtomko
« Reply #79 on: August 30, 2015, 12:45:04 PM »
Very nice work on this one, Martin!
Drew
« Reply #80 on: August 31, 2015, 01:15:09 AM »
Thank you very much for your kind words Gregory and Drew.
« Reply #81 on: August 31, 2015, 05:37:45 AM »
Martin,
The rigging is looking awesome! Terrific work so far!
« Reply #82 on: August 31, 2015, 09:34:19 AM »
Thank you for your kindly comment, Rick.
« Reply #83 on: August 31, 2015, 09:40:59 AM »
You are doing a great job with the rigging Martin, looking good.
« Reply #84 on: August 31, 2015, 09:45:45 AM »
Thank you Des. 8)
« Reply #85 on: September 01, 2015, 04:40:54 AM »
The second MG and the entire ammunition supply and discharge is installed.
The leather trim is painted around the cockpit and many decals mounted. The original crosses tear very easily, so I had to attach other.
Offline Pgtaylorart
« Reply #86 on: September 01, 2015, 05:37:17 AM »
Looking great, Martin!  It's nice to see a unique aircraft which is not often modeled.
George
« Reply #87 on: September 01, 2015, 06:59:36 AM »
Thank you for your positive comment, George.
« Reply #88 on: September 02, 2015, 05:01:02 AM »
Before I put on the upper wing, this model was sprayed with gloss varnish.
The control cables are threaded and glued.
« Reply #89 on: September 02, 2015, 05:24:05 AM »
This one continues to look FANTASTIC Martin! One of your best!
