Author Topic: Leicester/Canada Tribute Sopwith 1a Snipe - Airframe E 8213  (Read 17433 times)
Re: Leicester/Canada Tribute Sopwith 1a Snipe - Airframe E 8213
« Reply #75 on: September 16, 2015, 11:54:03 PM »
Looking superb, Chris!
Keep those updates flowing  ;)
VB
« Reply #76 on: September 17, 2015, 12:00:18 AM »
Vety fine update, Chris.
« Reply #77 on: September 17, 2015, 01:06:46 AM »
Chris,
   Superb job on the rigging, perfectly clean and crisp as always with your projects. I'm almost afraid to show mine when done, good luck with the struts and wing rigging, I have at least provided you with a scintillating example of how NOT to do that step! :-[ Looking mighty fine!
« Reply #78 on: September 17, 2015, 02:54:39 AM »
You are building (and painting) a superb looking Snipe! Lovely.
« Reply #79 on: September 17, 2015, 05:22:56 AM »
Absolute perfection in the tail rigging, Chris!  The Snipe is looking
just brilliant, with an unusual and pleasing colour scheme.  With
your dedication and eye for detail, I am looking forward to more
super updates, my friend. :D
« Reply #80 on: September 17, 2015, 08:15:36 AM »
Your Snipe is turning into a real gem Chris, the painting is so crisp and clean and the tail rigging is superb, this is going to be an extremely attractive model once completed.
« Reply #81 on: September 17, 2015, 01:38:25 PM »
I can't add anything better than what Des said! My thoughts exactly!
PS: Chris, I remember having the same issue on the piece you pointed out. That being said I didn't mention it in my build as after I realized the wing didn't fit flush on the real aircraft I thought I had removed it unnecessarily. In retrospect I am sure it was in the way. Like you said I probably did something wrong during construction.
« Last Edit: September 18, 2015, 11:47:04 PM by RAGIII »
« Reply #82 on: September 21, 2015, 08:53:22 AM »
Thanks fellows for your continued support! It means a lot to me. I'm happy that I have more progress to report. I'm a bit gun shy after having a serious issue with setting the cabanes in my D.VII project so I decided to try employing a jig this time around after seeing how well it works for Lance in his builds. It's simple to make and works like a charm. I'll be using one of these for all of my future projects.
Lance also had good luck in pre-rigging his cabanes which is something else I've never done, and seeing how the wing stagger might make it a difficult task, I followed suit and did it myself using Maxima Chameleon 2 lb monofilament as usual.
When I installed the top wing I ended up with one cabane line that sagged a bit but that was quickly rectified with a bit of heat from the tip of a soldering pencil.
The interplane struts all went into place in both wings without any issues and even without any rigging to brace the structure, it's quite sturdy on its own. I have to say that the stagger on the wings made reaching some of the connecting points somewhat of a challenge for my sausage like fingers. In particular, the cross-bracing between the struts was hard to get at.
The line that runs from the rear strut in the inside bay passes through the wing and anchors to the rear strut of the landing gear.
It's shown to good advantage in one of Jamo's Snipe photos as seen below. I hope you don't mind me borrowing it Jamo!
I used a 2 mm piece of brass tubing as my connector and found that it was too long. It's a tight space here by the time you factor in the eyelet!
I switched gears and replaced the 2 mm tube with a 1 mm piece and this fit perfectly.
The only other recourse would have been to pass the line fully through the landing gear strut, glue it in place, and forego using a connector. Luckily, it didn't come to that.
The cross bracing forward of the cockpit isn't well illustrated in the instruction booklet so it was a bit of a guessing job for me. The lines need to cross at the fuselage mounting points or else they'll touch the MGs.
With the wings rigged, I moved on to the landing carriage. Again, I found the instruction booklet less than adequate here but Jamo to the rescue again! He has some excellent photos of the rigging in this area. I don't know where I'd be without his excellent research and I applaud him for sharing it with us.
The model was leaning a bit to one side but that was easily corrected by applying some extra tension to the appropriate bracing line. Again, the landing carriage is quite stout on it's own and with the addition of the bracing, it's very sturdy.
So here's where she stands right now. About all that's left to do is paint the rigging, add the aileron control lines, install the engine, cowl, and propeller, and she's finished.
Thanks for looking in!
« Reply #83 on: September 21, 2015, 09:12:35 AM »
It's been awhile Chris , really love how this project is turning out so far .
« Reply #84 on: September 21, 2015, 09:46:30 AM »
Very nice work Chris!
« Reply #85 on: September 21, 2015, 10:32:43 AM »
Outstanding rigging work! Your Snipe continues to be an amazing build!
« Reply #86 on: September 21, 2015, 11:21:50 AM »
   Lovely work Chris, and you are now officially in the lead and by a large margin at that. Your rigging looks really good, and thanks for the comment on the crossing over of the lateral front cabane wires, I haven't done them yet and would probably have missed that until I rigged onto the guns! Such a clean overall Build, and such a unique subject as well, a totally winning combination. 8)
Offline Trackpad
« Reply #87 on: September 21, 2015, 12:54:15 PM »
Excellent work, Chris! You're 'way in the lead compared to me: haven't started yet! But the three for Ottawa are done and Ken's Herc is well underway. Might get back to fabric and wire sooner than I thought! <G>
Cheers!
Offline Pgtaylorart
« Reply #88 on: September 21, 2015, 12:57:18 PM »
Great work, Chris! The rigging is coming together very nicely!
George
« Reply #89 on: September 21, 2015, 07:00:34 PM »
Outstanding work, Chris.
