Author Topic: Leicester/Canada Tribute Sopwith 1a Snipe - Airframe E 8213  (Read 17556 times)
Re: Leicester/Canada Tribute Sopwith 1a Snipe - Airframe E 8213
« Reply #45 on: August 10, 2015, 07:59:56 AM »
Great update Chris! The guns look absolutely real and the entire component is clean and "crisp", I really think you've mastered the art of cockpit modules with this one, the degree of realism is stunning to say the least. Going to be hard to keep up to your high standards now! :o
I agree with everything that Lance has said, a superb build to date Chris.
« Reply #46 on: August 10, 2015, 08:53:57 AM »
 Chris,
Your Vickers are outstanding my old friend. No doubts in my mind this Snipe is your best to date. As always I'm looking forward to your next awesome update,keep up the excellent progress.
« Reply #47 on: August 10, 2015, 09:40:32 AM »
HI Chris:
Just catching up on your Snipe build here.  Great work all around Chris, the instrument panel looks great, tach decal slant notwithstanding.  I didn't see it.  The paint work on the seat belts and seat are top notch to write the least.  Guns and engine, what more can be said, looks the business alright.  Looking forward to  your next update.  Where are you getting the decals.  This is a neat bird!
Until that time
« Reply #48 on: August 10, 2015, 12:05:10 PM »
Outstanding work on the cockpit, Chris!  The guns look fantastic.
« Reply #49 on: August 10, 2015, 11:56:51 PM »
Thanks fellows. I'm having a lot of fun with this project, mainly because the engineering is so good.
. . . Thanks for the tip about attaching the ignition leads first.  Great idea and much easier than doing it
after the thing is all together. :D  Terrific progress, my friend!
I'm no fan of CA glue Ernie so I try to limit the potential for disaster when using it. I'm pretty lazy in that I don't scrape off glue attachment points so gluing together whatever I can before applying paint ensures the best joint. Sometimes it's a pain to paint pre-assembled detail but if I work my way out from the inner most pieces, it's not too bad.
. . . Where are you getting the decals.  This is a neat bird!
If all goes as planned, I'll make the 'Leicester/Canada' decals on my printer using laser decal paper as the decals are only black and white. As for the red over white striping, the plan going in is to mask and paint them. I'm reminded though that no plan survives first contact unscathed!
I'm open to, and seeking any suggestions from you more accomplished aircraft modellers on the best way to approach executing the stripes. Lance has already suggested painting the white portion followed by the application of a red decal stripe over that. Any input would be greatly appreciated!
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #50 on: August 26, 2015, 04:25:49 AM »
Engine and cockpit are both magnificent!!!! ;)
Lukas
Lukas
« Reply #51 on: August 26, 2015, 08:07:06 AM »
Chris,
I am sure whatever way you go with the stripes it will be fantastic! I have to say again just how gorgeous that cockpit and engine are!
« Reply #52 on: September 05, 2015, 04:08:05 AM »
I was sidetracked for awhile with an AMPS review project, but since getting back to my Snipe, I've made some progress, but not without continually shooting myself in the foot along the way. Rather than employing post-shading this time around, I decided to airbrush a slightly darker shade of CDL between the ribs on the underside surfaces to see how that looked.
All in all, I rather like the effect, so I decided to continue on with it. Notice how I shot the wrong side of the aileron though. :-[  This was my first shot in the foot.  Based on the following reference image, it appears to me that the under-surface wing tips are a different colour and I decided it was blue.
Note also the wide wrap-arounds framing the painted wingtips, which I also tried to reproduce.
Based on this reference image, the tips on the horizontal stabilizer are painted what appears to be a darker colour than the fuselage band. I decided the tips were red, so I carried that over onto the wings also. The top surfaces are Doped Aluminum which is a mixture of Tamiya Flat Aluminum and Sky Gray.
There is also some piping evident around the rudder and fin so I decided it was red too. I used a Sharpie to lay the colour down and I'm happy with the result. There's no way I could've done it as well as this with a brush or masking tape.
With the wings well on the way, I finished off the interior of the fuselage with some bracing at the tail end. I eventually removed the tail skid as it was getting in the way and I was afraid I'd break it. I'll add it later.
After gluing the fuselage halves together I threw caution to the wind and installed the cowling/doghouse. Hmmm . . . anyone see something wrong here? Maybe a gaping empty area behind the pilot's seat perhaps? Shot in the foot x2.
Yes indeed, I neglected to install the bulkhead behind the seat!  :-[  There was no way to gently pry the cowling off so I resorted to repetitively scribing the seams until it finally came off. Note that the bulkhead is now firmly in place. I cleaned up the seams and made the best of a bad situation.
With the fuselage fully assembled, I used masking tape and my airbrush to add the red and white striping. Then I shot the rear with Doped Aluminum, and determining that the fuselage band was blue, shot that colour also. It wasn't until I had removed all of the masking that I discovered that I had one too many red and white stripes. I can't for the life of me explain how I did that aside from pure carelessness. Shot in the foot x3.
There was nothing for it but to mask off the offending stripes and re-shoot blue over them. Everything went swimmingly until I suddenly realized that I could see the outlines of the stripes I had painted over.  :-[  Shot in the foot x4.
This time I sanded down the offending lines, re-masked yet again, and re-shot the blue. I think this time I have it pretty well fixed.
So, bit by bit, I'm fumbling along towards completion.
Thanks for dropping by!
« Reply #53 on: September 05, 2015, 04:40:00 AM »
Chris,
Really looking OUTSTANDING! Lovely paint work and the masked and painted stripes are terrific! Also your wing tip painting is awesome!
« Reply #54 on: September 05, 2015, 04:47:37 AM »
Very beautiful painting, Chris.
« Reply #55 on: September 05, 2015, 05:32:05 AM »
Awesome work, Chris!  But, please, stop trying to cripple yourself!
« Reply #56 on: September 05, 2015, 05:39:14 AM »
Hi Chris:
Great recovery on all of the self inflicted wounds!  :o  This is going to be a colorful bird and I am looking forward to seeing you progress.  Will it be ready for CAPCON?
Offline Pgtaylorart
« Reply #57 on: September 05, 2015, 06:04:48 AM »
Great work, Chris. Good to see you continue on and fix the errors instead of adding the model to a "shelf of doom". I did exactly the same thing last week with the ailerons on my DH.2. On the lower wing I painted the bottoms as the tops and vice versa, but I noticed it after I had already added Aviattic linen decals! Doh!
George
« Reply #58 on: September 05, 2015, 07:32:40 AM »
Thanks for your comments and support fellows!
I sure wish I could Bud but I seem to be moving from one careless mistake to another.
I was aiming for CapCon Mark but I don't know if I'll make the deadline. The way it's going, I'm not sure I want you guys to see it either!  :-[
« Reply #59 on: September 05, 2015, 08:29:32 AM »
Apart from stumbling along the way you have ended up with a really stunning looking airframe and wings, your painting skills are exceptional and the scheme you have chosen is superb, the blue on the fuselage is excellent. I also like what you did with the wings, the darker shade between the ribs worked very well.
