Completed models
Roland D.VIa
Topic: Roland D.VIa (Read 3267 times)
Kreston
Sr. Member
Roland D.VIa
June 15, 2015, 09:01:02 AM »
WNW Roland D.VIa 3612/18, Hans Jungwirth, Jasta 78b. This was a challenging and ultimately quite satisfying build. I used Aviattic lozenge, Gaspatch machine guns and turnbuckles (along with some pieces from Bob's Buckles), and EZ Line for the rigging. I am calling it finished but will probably add some additional weathering and fuel stains in the next day or two.
petrov27
Re: Roland D.VIa
June 15, 2015, 09:16:48 AM »
Very nicely done - kudos on the completion! I like the scheme choice and the presentation with the figure is tops!
-Patrick
Re: Roland D.VIa
June 15, 2015, 09:20:54 AM »
It was a pleasure to watch your build progress! Your results are terrific and the final presentation with the figure really sets the Roland off!
ragiii
coyotemagic
Re: Roland D.VIa
June 15, 2015, 10:34:08 AM »
Spectacular results, Kreston! Brilliant vignette. The Pilot and dog are as beautiful as that stunning Roland.
Des
Re: Roland D.VIa
June 15, 2015, 11:04:09 AM »
Very nicely done Kreston, the shade of blue you used is excellent, you did a spectacular job on the Roland and also on the figure and the dog,
Jacek
Re: Roland D.VIa
June 15, 2015, 05:46:58 PM »
Beautifully made Roland.
Congratulations !
Jacek
PrzemoL
Re: Roland D.VIa
Reply #6 on:
June 15, 2015, 06:00:43 PM »
A very nice one. That pale blue fuselage is very appealing.
Ssasho0
Re: Roland D.VIa
Reply #7 on:
June 15, 2015, 06:05:28 PM »
Wonderfull result you have
The blue is hard to execute but yours looks perfect!
Think globally, act locally!
LukasTheLight
Addicted to Wingnuts...
Re: Roland D.VIa
Reply #8 on:
June 15, 2015, 09:15:17 PM »
Hi Kreston!!!
What and beautiful and unusual camouflaged aircraft!!! Beautiful work!!!
Lukas
Lukas
lone modeller
Re: Roland D.VIa
Reply #9 on:
June 16, 2015, 03:30:34 AM »
What can I add? That is a really excellent model and the figure and dog just set it off wonderfully.
dr 1 ace
Re: Roland D.VIa
Reply #10 on:
June 16, 2015, 03:48:51 AM »
A strong ditto to all the above comments, Nicely done.
MS406
Jr. Member
Re: Roland D.VIa
Reply #11 on:
June 16, 2015, 06:49:03 PM »
Real nice work here! But those Gaspatch turnbuckles are hard to align are n't they!
Best regards from France.
Bluesfan
Re: Roland D.VIa
Reply #12 on:
June 16, 2015, 10:40:22 PM »
Beautiful work! I've always liked that scheme, and you've certainly done it justice.
And everything goes better with a dog.
lcarroll
Re: Roland D.VIa
Reply #13 on:
June 17, 2015, 12:03:30 AM »
Beautiful job Kreston, the colour and the overall muted tones really set this one off.
Kreston
Sr. Member
Re: Roland D.VIa
Reply #14 on:
June 17, 2015, 12:07:33 AM »
Thanks for all of the kind comments.
A word on the turnbuckles. This was my first time using them and found that when I was gluing them in place, I had to use my best guess at the correct angle for the EZ line. They are not easy to reposition...they can be adjusted a little but the metal does not easily bend. The wire on the far port side wing was not tight enough and looked like it was weightless. I have since taken it off and strung a new piece. It looks a lot better.
Completed models
Roland D.VIa
