Author Topic: Finished: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)  (Read 75157 times)
Re: 1/48 Voisin 10 Ca2 (modified Hi-Tech kit)
« Reply #45 on: August 22, 2015, 06:08:45 AM »
Simply gorgeous, Louis!  That gun, it itself, was quite the project.
Ditto My Amigo !!
« Reply #46 on: August 22, 2015, 06:40:04 AM »
Wonderful detail work, Louis. The canon is a model in itself, keep the updates coming! 8)
« Reply #47 on: August 23, 2015, 04:14:36 AM »
Perfect!.
Offline huberlu
« Reply #48 on: September 05, 2015, 06:36:58 AM »
Thank you very much!!!
Hello!
The engine is started:
I made it in two parts to be able to easily put the binding that connects the two parts.
The lengths are calculated from the plan with more or less accuracy ... Ditto for the general shape of the engine block.
You can find the plan here:
http://img11.hostingpics.net/pics/443899Renault12FeFi0003.jpg
http://www.hostingpics.net/viewer.php?id=205134RenaultV12220hpEndX.jpg
http://www.hostingpics.net/viewer.php?id=797815Renault12FeFi0001.jpg
http://www.hydroretro.net/etudegh/renault.pdf
The top of the cylinder head is flat:
The cylinders will be glued in pairs. we must also make a mold, making the two cylinders, gluing, sanding, decorate, remould them etc, etc ...
Offline huberlu
« Reply #49 on: September 05, 2015, 07:36:59 AM »
The four openings on the cylinders are cut into 1mm diameter rod:
« Last Edit: September 05, 2015, 07:49:31 AM by huberlu »
« Reply #50 on: September 05, 2015, 08:08:32 AM »
Outstanding scratchbuild!
« Reply #51 on: September 05, 2015, 08:21:49 AM »
You have made a great start with the engine, looking forward to seeing more.
« Reply #52 on: September 05, 2015, 08:52:17 AM »
  Louis,
As always my old friend Outstanding skill and craftsmanship. Looking forward to more.
« Reply #53 on: September 05, 2015, 11:13:17 AM »
Your scratch built engine parts are coming along nicely! Outstanding work!
« Reply #54 on: September 05, 2015, 01:59:20 PM »
Great stuff!
Offline huberlu
« Reply #55 on: September 26, 2015, 11:15:31 PM »
Thank you !!!
Hi !
I remade the cylinders entirely with evergreen plastic, I could not stick the small parts cleanly with superglue on the  resin parts, and their foot was too short. It was long and painful ...
The springs are made of copper wire (gold), found in "fly fishing" shop. It is thinner than the wire.
I wanted to make them conical. Well... believe me it is difficult to find the point suitable for winding the wire over.
Finally I 'm using an old needle (fine) my airbrush (Pasch).
Everything is covered with "surfacer".
Welds are plastic yarn stuck to the liquid adhesive and crushed with the back of the tweezers
The shape could have been crowned at the top ... but I do not want to start over.
Tomorrow I make the mold.
« Reply #56 on: September 26, 2015, 11:23:20 PM »
To me the Evergreen cylinders look even better! Very impressive work...again!
« Reply #57 on: September 26, 2015, 11:49:21 PM »
Excellent
« Reply #58 on: September 27, 2015, 05:00:39 AM »
Outstanding work.
Offline huberlu
« Reply #59 on: September 27, 2015, 05:01:30 AM »
Thank you !
