Author Topic: Sikorsky S-16 in 1:32 scale  (Read 37527 times)
Offline Whiteknuckles
Re: Sikorsky S-16 in 1:32 scale
« Reply #150 on: June 24, 2015, 11:21:47 AM »
Another great bird Des, wonderful model  :)
Eternal Apprentice
« Reply #151 on: June 24, 2015, 03:28:35 PM »
I would like to thank Terri, Bud, Scott, Bob and Andrew for stopping by and leaving very nice comments.
« Reply #152 on: June 25, 2015, 09:18:02 PM »
I made the struts from bamboo tooth picks, an easy timber to work yet very strong, they have been painted with Humbrol clear orange. I also fitted the top wing, took a little bit of messing around but finally got it to sit correctly, rigging is next.
« Reply #153 on: June 25, 2015, 09:30:14 PM »
Magnificent Des! How do you do the metal fittings at the ends of those wooden struts? They look 100% "real", an effect I struggle with on stock parts. :-\
Offline Pgtaylorart
« Reply #154 on: June 25, 2015, 11:43:46 PM »
Yes, I was also wondering about the metal fittings on the struts, Des. It's looking great!
George
« Reply #155 on: June 25, 2015, 11:55:44 PM »
Des, sorry I haven't commented on your update before this one! Your Model is looking superb as all would expect from your talented hands! Beautiful struts and it has now taken on the look of the S16 100%
« Reply #156 on: June 26, 2015, 12:08:12 AM »
Very, VERY pretty!!
« Reply #157 on: June 26, 2015, 01:11:39 AM »
Thanks very much Bo, Lance, Michael, George, Rick and Steve for your very kind comments.
The struts are made from 2.0mm round bamboo tooth picks, two sides are flattened until the strut is 2.0mm x 1.0mm. The metal ends are fashioned from 1.8mm brass tube, this is half flattened and then cut to length, it is then filed and sanded to shape before being slipped onto the ends of the strut, they are a force fit so no glue is needed to hold them in position. I drilled a 0.5mm hole in the end of each strut and inserted a length of 0.4mm copper wire, this is held in place with CA. For the rigging brackets I made them from 1.0mm wide coke can aluminium, drilled with a 0.4mm drill and cut to length then sanded to shape, thses are then fitted over the copper wire and CA'd in place. The struts are painted with Humbrol clear orange.
« Reply #158 on: June 26, 2015, 01:16:53 AM »
Truly remarkable, Des!  She looks like the real deal.
« Reply #159 on: June 26, 2015, 02:11:55 AM »
Thanks Bud for your kind comments.
« Reply #160 on: June 26, 2015, 06:17:09 AM »
Excellent progress, Des!
Well done  ;)
vB
« Reply #161 on: June 26, 2015, 06:28:42 AM »
Fantastic work Des.
Online PrzemoL
« Reply #162 on: June 26, 2015, 08:49:14 AM »
Yes, great is a good word to describe my feelings. Lovely model in the making, Des.
« Reply #163 on: June 27, 2015, 01:23:03 PM »
Many thanks to Bob, Martin and Przemol for posting your wonderful comments, they are much appreciated.
« Reply #164 on: June 29, 2015, 02:51:06 AM »
Sorry Des but I have been away for a few days and am catching up. That is a truly magnificent model - so compact yet so interesting to look at. Those early aircraft look deceptively simple - until one tries to scratch build one! You make them look deceptively simple too!!
