Author Topic: Sikorsky S-16 in 1:32 scale  (Read 37156 times)
« on: May 08, 2015, 07:59:34 PM »
I purchased a book on the aircraft which has some pretty good scale plans plus lots of period black and white photos. The aeroplane was originally designed as a side by side two seat trainer but proved to be quite a capable plane, so it was relegated to an escort/fighter roll. Being a two seater then changed to a single seater means that there is plenty of room in the cockpit.
I will be using the 7 cylinder rotary for this build, I already had one prepared earlier so that saved me a bit of work, this was the biggest downfall for this aeroplane, it was underpowered. It was supposed to have the 9 cylinder 100hp rotary but supply was an issue.
This plane was fitted with an undercarriage which had 4 spoked wheels, I wanted to show the spokes exposed so I purchased 4 wheels from John Vojtech at Scale Spokes, they are Spad wheels but are the exact right size for my build. John supplies a good variety of different tyres for his wheels including weighted resin tyres.
I will be using the high back wicker seat which I purchased from Barracuda Studios. This is a brilliant seat and again is the exact correct size when compared to the plan. I have painted this seat with Gunze Middlestone.
I have started making the fuselage from by using 1.5mm x 1.0mm styrene strips for the longerons and 1.0mm x 1.0mm for the frames. I will not be going to a lot of detail with the frame as it will be covered, only the cockpit area will get special attention. As you can see in these photos, the cockpit area of the frame is quite wide.
The engine firewall is made from 0.5mm styrene sheet cut to shape and sanded. I have trial fitted the engine at this stage. I will be using a modified left over engine cowl for this build, it needed to be re-shaped and lengthened.
I have been working on making the components to fit into the cockpit. This photo shows the fuek tank, the woven frame that sits on the fuel tank, the steering column and wheel, rudder bar, instrument panel with just the one instrument, the throttle quadrant and the hand operated pressure pump, obviously, none of these items have been painted yet.
And the final photo shows all the bits and pieces I have ready, I am awaiting the starting magneto and switch to arrive from Lukasz, these will be mounted in the cockpit as well.
Offline Ian from Doncaster
Re: Sikorsky S-16 in 1:32 scale
« Reply #1 on: May 08, 2015, 08:18:35 PM »
Ye gods Des, you're almost done!
I visited Sikorsky's HQ in the USA a few years ago, and I do recall seeing a model in their reception a WWI-era aircraft that I think was quite large - could have been the Sikorsky Ilya Muromets S-22?
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #2 on: May 08, 2015, 08:32:33 PM »
Hello Des!!!
It looks like a great start...as always!!! :) Another very interesting subject!
Lukas
Lukas
« Reply #3 on: May 08, 2015, 09:15:50 PM »
Thanks Ian and Lukas for your nice words.
Here are the main cockpit components sitting in position, I don't know what the idea of the woven frame was on top of the fuel tank but it is shown on my plans. I made the frame from 1.0mm brass wire and the woven fabric are narrow strips of coloured paper.
« Reply #4 on: May 08, 2015, 10:18:49 PM »
You are off to a excellent start so far Des  :) Following with interest  ;D
« Reply #5 on: May 08, 2015, 10:35:40 PM »
Brilliant start, Des. ;D
Will watch your next scratch build, like all in the last year.
All your builds are fantastic.
« Reply #6 on: May 08, 2015, 11:05:37 PM »
Very nice start, Des, and another great subject!
Offline Berman
« Reply #7 on: May 08, 2015, 11:52:40 PM »
Des,
       The three view drawing in that book shows a S-16ser which had a longer wingspan than the S-16. So are you building a S-16 or S-16ser?
        Incidentally, I have spare copies of that same book so if anyone is interested, please contact me.
                         Barry
« Reply #8 on: May 09, 2015, 01:40:57 AM »
Brilliant start on another of your unusual types. As usual I will be following along in search of hints and tips…. of which there will be many.
Offline Verbeek
« Reply #9 on: May 09, 2015, 01:46:32 AM »
What a great job you going to do, i love it when people can make it just out air (and styrene)  :)
Out of all the things I have lost, I miss my mind the most.
Offline malaula
« Reply #10 on: May 09, 2015, 01:57:53 AM »
Hi Des!Nice work as usual! I believe the wooden frame extended a bit further aft(or maybe the pilots seat  further to the front) and served as a provisional seat when flown as a two seater.I remember having seen a foto but haven't found it yet.  cheers  Matz
« Reply #11 on: May 09, 2015, 01:59:26 AM »
You're off on another extraordinary adventure, Des!  Outstanding work, so far.  Looking forward to following along.  I believe Matz is right about the seat frame.  I have the 1/48 scale Omega kit and that is how it is depicted.
Offline ondra
« Reply #12 on: May 09, 2015, 02:00:52 AM »
Great job all around, Des, this really looks excellent.
Could you please share how you made the fuselage framework with such precision? This could be a way to the future for me. :)
Many thanks
Ondra
Offline Pgtaylorart
« Reply #13 on: May 09, 2015, 02:40:14 AM »
Incredible, Des! You've made an amazing start on your model. The engine looks great and I love the little woven frame that the seat rests on.
George
Offline UFAG
« Reply #14 on: May 09, 2015, 08:03:38 AM »
Sweeeet...!!!
