Author Topic: Pfalz D.III question  (Read 1424 times)
Offline jknaus
« on: April 01, 2015, 09:13:33 AM »
I went and cut the handle off of the rad cooler door on my WNW Pfalz D.IIIa. I then went and cut a slit in the end of a .4mm tube and soldered it on and then added a tooth pick handle which I had chucked in a dremel tool and sanded down. Reasoning was that it was probably a limitation of PE. I cant find a good pic in any refs I have. After doing this I found one poor picture that now makes me think I made a mistake.
I guess this is a long winded way of asking, should it be flat or did I do the right thing?
James
Re: Pfalz D.III question
« Reply #1 on: April 01, 2015, 12:40:41 PM »
I think it was a simple welded T-handle made from steel rod presumably...
Offline jknaus
« Reply #2 on: April 01, 2015, 02:46:41 PM »
Okay, thats easy enough to fix. If its flat though then I'm in trouble. Thanks guys.
James
« Reply #3 on: April 01, 2015, 09:00:13 PM »
The guy's are right and it isn't flat . You done right  :)
Offline jknaus
« Reply #4 on: April 02, 2015, 12:07:39 AM »
Thanks Terri. Will remove the handle and solder on another. :)
James
