Author Topic: Blackburn Heavy Monoplane  (Read 33515 times)
Offline Royston
Re: Blackburn Heavy Monoplane
« Reply #75 on: March 07, 2015, 01:33:04 PM »
Those brackets really add the wow factor, nice contrast to the wood
Roy
« Reply #76 on: March 07, 2015, 03:33:44 PM »
Thanks very much Warren, James, Petrov, George, Bo and Roy for your mextremeoly kind words, they are much appreciated.
Offline ondra
« Reply #77 on: March 07, 2015, 03:58:20 PM »
Des, many thanks for sharing the progress and for showing me new horizons of what is feasible in scratch builds.
This is just brilliant!
Ondra
Offline Cimmerian
« Reply #78 on: March 07, 2015, 10:37:00 PM »
Wonderful work.
Regards, Ken
« Reply #79 on: March 08, 2015, 12:57:57 AM »
Hi Des,
 It's Always a pleasure to view your progress and this heavier than air contraption is no exception  :D
Excellent details.
« Reply #80 on: March 08, 2015, 06:32:47 AM »
Many thanks to Ondra, Ken and Bob for your nice comments, and you are spot on with your description of this "aeroplane" Bob, it is certainly a contraption.
« Reply #81 on: March 08, 2015, 11:24:39 AM »
Great work from an exellent model builder Des.
« Reply #82 on: March 08, 2015, 06:02:27 PM »
Thank you Martin for your kind words.
I made the two radiators and fitted them to the airframe, they are a very basic radiator with wavy mesh. I also fitted the prop shaft and mounting brackets along with the sprocket, the propeller displayed here is for size purposes only, it is not the propeller that will be used. The last photo shows the roller chain under construction, it will eventually mesh with a sprocket on the engine with a 2:1 drive to the propeller.
This is the bike chain set I am using for the roller chain, it is from Model Factory Hiro and is set No. P-941. It is a reasonably easy set to assemble and is quite strong once together, the small pins need to be melted and I found the ideal temperature to do this was 187ºC which is not too hot that it melts the pins off. There are enough parts to make three full lengths the same as the one on the sprocket.
« Reply #83 on: March 08, 2015, 06:27:58 PM »
Goodness me that's a beauty Des!
And the speed you're coming along!
Offline Royston
« Reply #84 on: March 08, 2015, 08:00:49 PM »
nice update Des, the pipes connecting the two rads is a really neat idea.
Roy
« Reply #85 on: March 08, 2015, 09:34:32 PM »
Wow! Des, the radiators and the chain are so cool!  Well done, my friend. :D
« Reply #86 on: March 08, 2015, 10:20:48 PM »
This is looking so good, Des, and following the build is a real pleasure.
Offline LukasTheLight
  • Addicted to Wingnuts...
« Reply #87 on: March 08, 2015, 10:46:28 PM »
Hello Des!!!
What a build!!! Again and again... you are just making me want to try scratch build more and more(when I have a chance)... It looks so effortless done it by you though!!! Love your furniture building skills too!!! ;)
Lukas
Lukas
« Reply #88 on: March 09, 2015, 02:56:43 AM »
Fantastic update Des.
« Reply #89 on: March 09, 2015, 03:29:43 AM »
More super work from the Master. The chain and radiators look really good - how did these things ever get off the ground?
